Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-04-2007, 08:27 PM
N4NV N4NV is offline
N4NV is on a distinguished road
47mm bearing spacers
I am looking for a place to purchse some 1mm, 2mm and 3mm spacers for a set of bearings that have an OD of 47mm and ID of 20mm. A web link would be appreaciated.
Vince
Old 02-05-2007, 03:07 PM
NC Cams NC Cams is offline
Choices for EXACTLY what you're looking for are small.
BUT, you can check out Smalley for wave and other similar washers that are used for preloading the outer ring of electric motors. These may address SOME of the sizes you're looking for. McMaster-Carr sells them and maybe Grainger as well.
For EXACTLY what you want, you're probably better off having some lazer cut. Simply call a lazer cutter and have then make some out of hard steel shim stock.
Try the guys at Lazer Cutting (586-468-5300). They're in Clinton Twp Michigan. They made some valve spring shims for me and that's what we had them make them out of. They had various thicnesses of materials in-stock and could readily get whatever else we wanted/needed.
All you'll typically need is a DXF file of the "washer" and a verbal description of the thicness(es) that you want/need.
Old 02-05-2007, 04:07 PM
I fount that Musimi will make the spacers I want to my specification for $7 each plus shipping. No minimum order. I ordered the one I want. They should get here in a couple of weeks.
Vince
Old 02-05-2007, 10:32 PM
BobWarfield's Avatar
Vince, do you have a link for the Misumi spacers?
Best,
BW
Old 02-05-2007, 11:19 PM
walter's Avatar
walter walter is offline
walter is on a distinguished road
Bearing spacers in Misumi catalog:
https://fa.misumiusa.com/gwos/catalo...ATEGORY_ID=007
Old 02-06-2007, 07:40 AM
Best,
BW
http://tinyurl.com/2gexau
You have to have an account to request custom spacers. Once you get on the above page there are about 12 more steps to select a custom spacer. I would suggest you call Misumi and ask for technical support and have them step you through it. It took me 30 minutes on the phone to get through the entire process and that included signing up for an account. If you are using IE 7 you will also have to make a change to the setting to get the custom order screen to function properly.
Vince
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing sala84 JGRO Router Table Design 7 11-03-2006 09:42 AM
Bearing Arrangements Ursine Mechanical Calculations/Engineering Design 2 03-21-2005 05:24 AM
RFQ - Aluminum plate and spacers tjstraz Employment Opportunity and RFQ (Request for Quote). 3 01-26-2005 08:25 PM
Bearing in MDF Photon DIY-CNC Router Table Machines 6 05-20-2004 04:18 PM
