Old 02-01-2007, 08:38 PM
inertialabs inertialabs is offline
inertialabs is on a distinguished road
Spindle woes
I have a Bridgeport VMC 760 with a DX 32 controller and Siemens drives. I recently purchased the machine from a shop down the street and I had the chance to see it run before I bought it Everything seemed fine and in good working order. I have the mill powered up and running fine with everything but the spindle. If I put in a spindle command over 2000 RPM I get an alarm that reads
" MSG 05:15:21n PM Axis Drive Fault " The interesting thing is that if I bump up the spindle rate 200 RPM at a time I can get it up to 6K RPM. So to me it seems like the current draw spikes and trips the alarm with too big of an increase. I found the settable breaker in the cabinet and clicked it up to 25 amps but I am pretty sure it is not blowing. I also put a AC clamp meter on the 3 legs of the spindle drive and got equal readings around 8 amps while spinning at any speed and 24 max increasing RPM. That is what I learned today, I am not sure what to do next and I would surely appreciate any suggestions. Thanks
Reason Bradley
Old 02-02-2007, 06:59 AM
gus gus is offline
gus is on a distinguished road
re
I wonder if there is a difference in voltage from one shop to the other, causing a too high current reading in your shop
Old 02-02-2007, 07:14 AM
gridley51 gridley51 is offline
gridley51 is on a distinguished road
Could be like Gus says.Try increasing the ramp up time to see if it stops faulting.
Mark.
Old 02-02-2007, 09:25 AM
spindle woes
Hello Gus, Chipsweeper
Thank you for your insight, The answer to your question is definitely yes the old shop had Y and we have Delta from a CNC Rotary phase converter then going through a Capacitor bank then to the machine.
Voltage to Ground
Leg 1 119
Leg 2 125
Leg 3 240
Voltage between legs
245
250
270
This voltage does not sound great but all the other axis drives seem to be working perfectly, witch supports your RPM ramp theory.
I like the sound of increasing the ramp up time that sounds like a smoking gun to me, The only problem is I am not sure how to increase the time. Any suggestions on how to achieve that are welcome
Thank you both for you help
Reason Bradley
Reason Bradley
reason.bradley@gmail.com
415-596-3946
Last edited by inertialabs; 02-02-2007 at 09:34 AM. Reason: Added a couple more details
Old 02-02-2007, 02:17 PM
First of all set the breaker back to its original setting,it`s there for protection.
I`m not familiar with that control,what model of Siemens drive do you have?
Mark.
Old 02-02-2007, 07:02 PM
gus gus is offline
re
Woa, phase converter, that is the tipoff. Can't generate the same torque with that. You are going to have problems of some sort I think no matter what
Old 02-02-2007, 07:25 PM
Thank you I will set the breaker back immediatly, The controll is a siemens Semodrive 611
Old 02-02-2007, 07:29 PM
Yes I know they are not ideal, But it is a rotary type 30 HP CNC Balanced motor as you see it is barely in the 10 Pecrent range but I am currently running another Kitamura mill and a lathe off of them with no trouble, Is the voltage the concern or the lack of amperage ?
Old 02-02-2007, 07:36 PM
machintek machintek is offline
machintek is on a distinguished road
If you really need to have a phase converter, you need a digital one.
Obviously, there is not enough watts (area beneath the curve) to accel this mass in the given period of time.
Although there are tuning cards on the axis drives, you do not see any on the spindle drive. it is all done in parameters.
Also the Bridgeport installation sheets specify that you need balanced power.
There is a matching transformer on the bottom of the electrical cabinet but not for a rotary phase converter.
George
Old 02-02-2007, 07:41 PM
Any Idea of how you change the parameters of the acceleration curve ?
Old 02-02-2007, 10:17 PM
I have a list of parameters that are changed when installing a new spindle drive. i do not remember if i have a list of descriptions of these parameters. Next time in the office, I will check.
George
Old 02-03-2007, 03:26 AM
Be very careful with the 611 drive.Some of the early servo controllers fitted to machines do not have phase loss protection.If a phase goes down while power is applied to the 611 it will blow.I have one here on a retrofitted Warner Swasey I bought.Put the main panel isolator on one day,powered the machine up,it came up,the lights flickered and it died.Found a fault in the main disconnecter,replaced it,powered up and got one of the bigger bangs I had heard in a long time came from the drive.Called up Siemens and explained what had happened,the guy asked "has a phase gone while power was on the drive?"
Yes."well you have lost the drive,you will have to return it to us for repair"
You can now buy a little box to add to the drive that senses the power going and shuts it down before damage is done.
So I have estimates of $2000-$2500 to repair this but it could be repaired and a mains failure occur the next day and bang it`s gone again.Other thing I don`t like about them is dc link voltage of 660 volts.Fatal stuff if you get caught by that.
If you have an email address I can post you pdf`s for the drive if George can`t find his.
Mark.
Wiring Woes..... Normsthename General Electronics Discussion 54 01-03-2007 03:38 PM
Any clues on my LPT woes? Greolt Machines running Mach Software 10 10-16-2006 01:51 AM
THK HSR35 woes Corvus corax Linear and Rotary Motion 5 11-07-2005 08:14 PM
Woes of a newbie posix Stepper Motors and Drives 3 04-13-2005 10:54 AM
Z axis woes yukonho DIY-CNC Router Table Machines 48 02-29-2004 12:02 AM
