Old 02-01-2007, 07:20 PM
Mr.Chips's Avatar
Mr.Chips Mr.Chips is online now
Mr.Chips is on a distinguished road
Question Keep Cables from tangling
What are the plastic guides called that keep the X and Y axis cable from tangeling? They curl up and uncurl when the axis moves.
What do the individual segments look like?
Any homemade ones out there?
Hager
Old 02-01-2007, 08:00 PM
Weldtutor's Avatar
Weldtutor Weldtutor is offline
Weldtutor is on a distinguished road
There is a thread HERE for the Igus energy chains (cable carrier)
Old 02-01-2007, 11:20 PM
Mr.Chips's Avatar
Smile
That's it.
Hager
Old 02-02-2007, 08:51 AM
jcc3inc jcc3inc is offline
jcc3inc is on a distinguished road
Sir,
Sometimes they are called "powertrack". Several co's make them; they are usually plastic and they snap together. Some have removable caps to ease the process of placing the cable in them.
If you want to keep costs down, consider a heavy spring which is tied to a fixed part of your machine and is also attached to your moving member. The spring can be a flat steel spring material like the device which electricians use to run wire thru conduit. I bought a "drain de-clogger" for a low price, cut off the length needed, and tied my wires to it.
Regards,
Jack C.
Old 02-02-2007, 11:56 AM
planekrazie's Avatar
planekrazie planekrazie is offline
planekrazie is on a distinguished road
This Sounds interesting. Could you post a pic o link of some sort for this.
Much thanks Steve
Originally Posted by jcc3inc View Post
Sir,
Regards,
Jack C.
Old 02-02-2007, 12:12 PM
The spring can be a flat steel spring material like the device which electricians use to run wire thru conduit. .
It's known as a 'Fish Tape' Home Depot have them in the Elec. section.
Old 02-03-2007, 09:57 AM
Wire handling
Planekrazie,
I will attempt to add 2 pix to show what I did.
Regards,
Jack C.
ID:	30872   Click image for larger version
Old 02-03-2007, 10:29 AM
Mr.Chips's Avatar
Smile
Planekrazie,
Regards,
Jack C.
This is a good and simple idea. And I like simple.
Hager
Old 02-03-2007, 10:50 AM
CNCRob's Avatar
CNCRob CNCRob is offline
CNCRob is on a distinguished road
I seen someone on here even use the tape part (the part with the numbers on it) of an old tape measure to make one. I can't remember which thread it was now though.
Robbie
Old 02-03-2007, 10:52 AM
CNCRob's Avatar
Planekrazie,
Regards,
Jack C.
Very nice, I like the way that looks.
Robbie
Old 02-03-2007, 11:14 PM
Madclicker Madclicker is offline
Madclicker is on a distinguished road
WOW, never thought of fish tape. It will work perfectly for me. My fish tape is on a reel and I don't want to wreck it. If I remember right it is only $6 or so for a wind of it. Might try harborfreight.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 02-04-2007, 02:37 PM
Rance's Avatar
Rance Rance is offline
Rance is on a distinguished road
Neat idea Jack. Others looking for material to use might consider 1/4" pvc tubing or similar. Maybe tubing you use to hook up icemaker for a refrigerator. It's flexible but somewhat stiff, can bend in a 'U', and gives you something to zip tie your cables to.
Encoder Cables JavaDog General Electronics Discussion 16 09-11-2007 03:51 AM
Powermax II cables moto21 Stepper Motors and Drives 3 04-09-2007 03:56 PM
Cables itsme General Electronics Discussion 3 05-22-2005 02:35 PM
How to build stepper cables? buscht Xylotex 7 04-29-2004 02:50 PM
Servo cables SJ781 General Electronics Discussion 3 10-31-2003 10:42 AM
