From Ohms law, 2 amps at 1 ohm is equal to 2 volts. The general rule for steppers is to use a supply 10 to 20 times the motor rating, so something between 20 and 40 volts.
PS Since it is an eight wire motor, you can't really be sure what the rating on the nameplate is for. Generally, with an 8-wire motor, the rating is for a single coil, or unipolar connection. However, if it came wired for bipolar parallel, the rating may be for the parallel connection. If you have a meter with a low enough Ohm range, you could measure the coil resistance to be sure.
