Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > General Electronics Discussion
General Electronics Discussion Discuss basic electronics, power supplies and anything else electronic related here.
Old 01-22-2007, 07:12 AM
epineh epineh is offline
epineh is on a distinguished road
Hacking A Printer To Directly Print PCB's
I have to say first up that this is not my idea, I'm just following in the footsteps of this fella here :
http://techref.massmind.org/techref/pcb/etch/c84-st.htm
The build starts with me buying a perfectly normal Epson C87 Stylus inkjet printer. The mods in the above page describe a C84 printer, which is no longer available new, I just hoped that the C87 was similiar enough to do the same thing.
Anybody following my second router build will know that I have the next three months to build the electronics for it, I won't go into too much detail here, but enough to say that I need to make quality PCB's for my microcontroller experiments and other CNC stuff...after a lot of research, I decided to take the path of modding a printer to fit a blank PCB with a base carrier directly through, involving raising the print head mechanism and associated equipment. The result is being able to print directly onto the board, the ink forming a "resist" layer that will not let the copper dissolve when etching, leaving the required artwork.
AnyHoo, here is the obligatory "before" shot of the printer:
Russell.
Old 01-22-2007, 07:31 AM
Here I have started to remove the covers, as you may have noticed, the paper feed is from the top... not very good for PCB's, they don't tend to bend around the paper guides very well, I can feel some "modification" is needed here
ID:	30124   Click image for larger version
Old 01-22-2007, 07:34 AM
I wonder if I can sell these bits on ebay...lol
Old 01-22-2007, 07:38 AM
Switcher's Avatar
Switcher Switcher is offline
Switcher is on a distinguished road
Actually you might be surprised, I think they would sell.
My wife dropped a tv on one of my all-in-one printers (not the same printer you have) broke the glass & some plastic.
Try ebay, you never know!
Old 01-22-2007, 07:54 AM
Now the procedure is this... the blanks are 1.6mm thick, I have allowed for a 1mm base "carrier" piece, either card or sheetmetal, to use for aligning and transport. This means that the print head assembly needs to be raised by 2.6mm to allow all of this to pass through, simple... maybe not THAT simple...
Here is the first cut, as you can see it is as simple as cutting along the dotted line, lol. I used some insulation tape and plastic pieces to catch the cuttings.
It is a really weird feeling to buy a new printer, then proceed to cut it in half with a hacksaw blade...for me at least.
Thats funny Switcher, I am now kinda thinking of trying to put some of the covers back on, and maybe engrave something on it with my router... like "Genetically Modified" or something like that... hehe
Russell.
ID:	30127   Click image for larger version
ID:	30128   Click image for larger version
ID:	30129   Click image for larger version
Old 01-22-2007, 07:58 AM
It might be a little hard to spot, but the last bit needing cutting is a little tab.
ID:	30131   Click image for larger version
Old 01-22-2007, 08:08 AM
Now I need to "adjust" the height and fix into place, I used some bits and pieces I had lying around, the tin plate is from a washing machine bracket.
Also the head cleaning station had to be lifted to work, not my prettiest work, but once those covers are back on...
ID:	30133   Click image for larger version
Old 01-22-2007, 08:17 AM
Next is the optic sensor for the paper feed, I located it to the opposite side to allow a bit of extra cable, instead of using the little lever setup, it will detect the carrier directly, which will have a little corner cutout to allow easier setup and alignment (I hope).
Its late here now... gotta sleep, need to let the silicone set on the sensor anyway. I installed the print drivers and ink cartridges, it all works fine, doesn't seem to know it has been tampered with...lol
Russell.
ID:	30135   Click image for larger version
Old 01-22-2007, 03:15 PM
Bent Bent is offline
Bent is on a distinguished road
Very interesting.
Keep the pics coming.
Bent
Old 01-22-2007, 04:14 PM
mlaws1172 mlaws1172 is offline
mlaws1172 is on a distinguished road
Great stuff! Maybe you need to modify and sell some.
mike
Old 01-22-2007, 04:40 PM
paulC paulC is offline
paulC is on a distinguished road
Russel
What do you use for ink? Is there something waterproof that you can load into a cartridge or are there waterproof ink cartridges available?
I take it you know about the laser transfer method.
http://www.fullnet.com/~tomg/gooteepc.htm
Paul
greybeard's Avatar
greybeard greybeard is offline
greybeard is on a distinguished road
Morning Russell.
Great work. I shall be watching to see where you paint the go-faster stripes
John
"It's like doing jigsaw puzzles in the dark"
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
keyboard hacking dertsap General Electronics Discussion 19 11-16-2009 12:42 PM
How to print ion a 3d surface whiteriver Printing, Scanners, Vinyl cutting and Plotters 2 07-09-2007 05:51 AM
Hacking up a bad controller originator General Electronics Discussion 34 10-07-2006 09:14 PM
cant print? erase42 BobCad-Cam 12 12-22-2005 03:38 PM
2d print from solidworks Kool Parts Solidworks 7 02-03-2005 10:12 AM
