Old 01-14-2007, 10:54 PM
tool_man tool_man is offline
tool_man is on a distinguished road
My first casting
This casting is a base for a steam engine.Dimensions are 21" X 8 5/8" X 4 1/4".Weight is about 30#.It was cast in petrobond sand.
The frame of the engine will be a great deal more intricate so,I think I will try lost foam.Since I do not have a CNC machine or access to one,I will have to cut individual peices and attach them.The way I see it,I have 2 options,glue the peices together,or use long,thin pins to hold the peices together,coat them with a few layers of drywall compound,then pull the pins out and recoat.Any thoughts on the second method would be greatly appreciated.
Thanks to all those who have shared their knowledge on this forum.
ID:	29601   Click image for larger version
Old 01-20-2007, 02:02 AM
LUCKY13 LUCKY13 is offline
LUCKY13 is on a distinguished road
Considering I dont know much about casting when I say this. But your casting looks like it was a fine job. Would you share more info on your method & metal. It seems to be alot smoother & better casting than what I have seen from most. But like I said I dont know much about & maybe just havnt seen the right work from others. Good Job as far as I am consirned. I hope I get this good of a result when I make my first casting.
Jess
Old 01-20-2007, 11:45 PM
WilliamD WilliamD is offline
WilliamD is on a distinguished road
That is a nice HUGE casting! What kind of foundry setup do you have?
Old 01-21-2007, 05:59 AM
Switcher's Avatar
Switcher Switcher is offline
Switcher is on a distinguished road
Nice job!
Looks like a fun project.
Old 01-21-2007, 10:53 AM
Thank you for the kind words.The alloy is #356.Shrinkage is very low.Keep the temperature under 1500 degrees F. to avoid hydrogen porosity.
It was cast in petrobond,availlable from Budget Casting supply.Parting compound is Plumbago(graphite).Be sure to round off corners and allow about 2 degrees taper of the sides of the pattern.After your remove the pattern,inspect the cavity and remove any sand that might be in the mold.I used a vacuum to do this but,be carefull not to touch the cavity.Some use very low air pressure to do this.
I fully expected the first casting to be a total failure but,if you take your time making the pattern and the mold,the results will be very rewarding.This is not rocket science but it does require care and attention to details.Good luck.Looking forward to seeing your first casting.You can do this.
Jess
Old 02-07-2007, 12:48 AM
chuggins143 chuggins143 is online now
chuggins143 is on a distinguished road
Schnikeys! That thing is huge! How big is your crucible?? ...and I thought my one gallon crucible was big!
Chad
Tucson, AZ
Old 02-07-2007, 06:16 AM
ImanCarrot's Avatar
ImanCarrot ImanCarrot is offline
ImanCarrot is on a distinguished road
Very impressive! my brother is a metalurgist and there's more to casting than meets the eye. Nice one
I'm pink therefore I'm spam.
Old 03-21-2007, 07:52 AM
sailandoar's Avatar
sailandoar sailandoar is offline
sailandoar is on a distinguished road
Lost Foam
Maybe the best lost foam site I have seen:
http://www.buildyouridea.com/cnc/hblb/hblb.html
Great lost foam page: beginner doing some large sections and complex shapes and it is very well documented.
http://www.submarineboat.com/sub/foundry.html
Another Great lost foam page:
http://www.enigmetallic.com/LFMC.htm
Lost Foam: worth a quick look
http://www.plansandprojects.com/My%2...s/lostfom1.htm
Lost Foam: not detailed but interesting
http://www.geocities.com/marcus_loignon/casting.html
Old 03-21-2007, 11:44 AM
jgro's Avatar
jgro jgro is offline
jgro is on a distinguished road
Nice job on your first casting!
jgro
Old 03-26-2007, 12:00 AM
Legion99999 Legion99999 is offline
Legion99999 is on a distinguished road
All i can say is wow! Sure beats the 10 ounce capacity of my electric furnace
Old 03-29-2007, 12:28 AM
metalworkz's Avatar
metalworkz metalworkz is offline
metalworkz is on a distinguished road
I agree, nice looking casting. I don't even see any signs of shrinkage and those look like fairly thick walls. I love petrobond it leaves a very smooth finish and is good for retaining fine details in the mold. How big is your crucible? I hope to see any other castings you make for that project.
Wes
