| Benchtop Machines Discuss all mini mills sherline, taig, square column, round column and CNC mill conversions here! |
#25
Most of what I've read about using ballscrews on the X2 say that one needs to mill the bottom of the table for the x-axis not to fit. Did you do this? Do you have a photo of the before and after? Jay |
| Sponsored Links |
#26
Hey Jay,
You do have to remove a little material from under the saddle to give clearance for the ballnut. I just used and angle grinder. Here's a pictorial that hopefully explains it. I didn't take any pics of the before and after, but was able to compile something close. Hope this helps. Also have a high res .zip of the drawing and the ballnut stop blocks rev B.dxf that shows changes I made to the X Axis block to give more clearance. Later, Hoss |
#27
Hoss your the man.
Jay |
#28
Hey Gang,
Finished my High Speed Spindle Motor attachment. Will use it mainly for engraving and grinding. Used a Dewalt Laminate Trimmer Model #DW670 I bought at Lowes. http://www.lowes.com/lowes/lkn?actio...670&lpage=none It has a 1/4 in. collet ( I made an 1/8 collet for it) and 34,000 rpm. Very nice quality item with no backlash in the spindle. Has a machined housing that fits nicely in the mount that I made to hold it perpendicular and true. Below are pics of the drawings and finished parts. The spindle is offset 3 in. from the X2 spindle on the X Axis as it's mounted here but it's able to mount on either side or the front. This should work well. Later Hoss P.S. As you can see I need to mount the Spindle Lock I made on the front yet, that's next. |
#29
Hoss,
Your ideas are refreshing and you sharing so freely to the forum is very much appreciated. You sent me your plans earlier on and I will be copying your Z axis design on my X2 shortly. Try this link here for some covers for your Z axis column. http://www.littlemachineshop.com/pro...itFast=bellows
cheers, Rod Perth, Western Australia |
#30
nice !!!!!!!!!
This is exactly what I have in mind. I did not read your post before I posted mine. You say you are not happy with the size? I am planing a buid for the model 47158, which is smaller. Should I splurge for a larger mill?
What are your plans for the speed control, this is were I get lost. Thanks for posting your motor mount designs they will come in handy. How about your milling speed? How does she do with alluminum? Great build and thanks for the information. Nice, Chris |
| Sponsored Links |
#31
Hey Chris,
I'm quite happy with the size of the X2, it will handle just about anything I plan on making, It's just the X3 is bigger and bigger is better, usually. Spend as much as you can afford, that's what it really comes down to. Plus the X1 and X2 can be handled without to much exertion but the X3 at over 300 lbs. could be a bear. I'm working on a control panel to control the mill 'manually' thru Mach 3. I have the speed control built in but it's manual right now, I'll figure out how to control it with g-code later. It will require rewiring to bypass the E-Stop and a Variable speed switch because If you interrupt power, the Variable speed switch needs cycled off then on again. I know the paperwork for the cnc controller talked about it,so I'll have to dig it up again. I'll post it when It's done. The mill can handle aluminum pretty well as the following pics show, but it is for light work. Can't go whole hog like at work, but this is at home. Heres a hint at the control panel, Should be done this week. Later Hoss |
#32
Hoss,
Your conversion is exactly what I am looking for! Do you have all this info in a zip file? Thanks Bill
Thanks Bill |
#33
Bill, did you read the thread? Look at post #21 and #26
#34
Yes I did, twice, I did not know if he had added everything after that post, Hmmm, Mabey I should have looked.
![]() Besides, it was late and I felt like this ....
Thanks Bill |
#35
Hey Gang,
Here's some more pics of my control panel for Mach 3. I'll hook it up tomorrow and add my DRO on top. I took 2 USB controllers, an aluminum case, a bunch of switches and some wire and came up with this. I'll use Keygrabber from Mach 3 to program the buttons. I can control (4) 110 V accessories, i.e. the engraver, light, vacuum. I have a duplicate X2 Speed Control switch from Littlemachineshop.com. http://www.littlemachineshop.com/pro...282&category=6 I added Jogging feedhold switches with LED's for taking long 'manual' cuts. Still have about 10 buttons unused available for future plans.(maybe Mach 4?) Next on the agenda, a surface grinding attachment. Stay tuned. Later Hoss |
| Sponsored Links |
#36
Looks great, you don't to anything halfway do you
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| Thread Tools | |
| Display Modes | |
