Old 10-08-2006, 05:55 PM
biomed_eng biomed_eng is offline
biomed_eng is on a distinguished road
What foam for aluminum casting?
In the past, we had parts aluminum sand cast using patterns hand shaped from mdf and bondo.
I now want to move to cnc'ing the patterns out of some type of foam. What foam should I use? Name brands? Types? I am totally new to foams.
I would like the foam to be as "light" as possible so that I can run the cnc faster than with "heavy" foam. However, I presume that the foam needs to be heavy/stiff enough so that when the foundry is pressing the pattern into the sand that the foam does not compress or break.
If you know of good foam suppliers for this kind of stuff in the Southern California are, please feel free to recommend them.
Thanks!
Old 10-08-2006, 06:08 PM
Kipper's Avatar
Kipper Kipper is offline
Try a google of "lost foam casting" you'll then see the way to approach this method. The main difference being no binder in the sand and that the sand is usually dry. Most of the lost foam casting i've seen has been gated only at the top...you may want to look at traditional gating and risers as i'd think it would give a better finish and a closer grain in the casting. Never bothered with it myself but once you see it you'll know how it's done. Any pottery suppliers near you? they have nice slips you could use hth
Keith
Old 10-11-2006, 01:55 PM
Thanks for your suggestions.
I am interested in using a regular sand casting process, not lost foam casting. I am only doing one-off projects.
I would like a foam that I can CNC and then give to the sand caster. Ideally, the foam would not be damaged by them pressing it into the sand.
Old 10-11-2006, 03:05 PM
ViperTX ViperTX is offline
Check buildyouridea.com he uses foam for aluminum casting forms.
Old 10-12-2006, 02:43 AM
toneV8 toneV8 is offline
toneV8 is on a distinguished road
I have one question:
lost foam casting process, for example using 10mm foam sheet when cast aluminium how much is dimensions after 10mm aluminium sheet more or less.
Old 10-13-2006, 12:50 PM
I believe the shrinkage is about 10% for a cast aluminum part....break out the mechanics bible....
Old 11-27-2006, 12:45 PM
RdHawg RdHawg is offline
RdHawg is on a distinguished road
He does - but it's all 'lost' in the process. I believe the poster is looking for a foam that will be able to be re-utilized.
My question now is, if your only doing a one-off then why do you care if the foam goes away?
Old 01-13-2007, 11:50 AM
acondit's Avatar
acondit acondit is offline
acondit is on a distinguished road
Patternmakers use 1/4" per foot shrink rules for aluminum (about 2%).
http://www.alansmachineworks.com
Old 02-18-2007, 03:18 PM
schemo schemo is offline
schemo is on a distinguished road
it more like 1-2% for aluminum
for 10% you must be thinking of jello
Old 03-12-2007, 06:36 PM
venomx999's Avatar
venomx999 venomx999 is offline
venomx999 is on a distinguished road
Best foam i've used are regular insulation foam.
They are thick and soft, when casted, take the perfect shape with 1-2% shrinkage.
Try to use a coating outside the foam. Home made formulas is dry wall paste mixed with masontry cement. Your casts will be as smooth as the foam you prepared.
Live life like you never see another day
Old 03-13-2007, 10:30 AM
chuggins143 chuggins143 is offline
chuggins143 is on a distinguished road
I too have seen several websites where the person casting just takes the foam part with risers and all, dips them in thinned out drywall compound (thinned out enough to flow into all the nooks and crannys) several times to get a good thick coating. Lets it dry and then pours dry sand around the whole thing to support it during the pour. This will be the route I go when I finally get my furnace fired and am ready to start pouring parts. ...just my .02
Chad
Tucson, AZ
