Old 01-06-2004, 02:37 PM
awm awm is offline
awm is on a distinguished road
Question Very Basic Scale DXF Question
Hello all and thanks in advance for your patience and assistance
I am very new to this BobCAD program and thus far I am adapting fairly well. The question I have is when I merge a DXF file into v17 no matter the original dimensions of the drawing it comes in at like 300+ scale and then I must then scale it down to scale 1 in order to have an accurate cut of course. The problem is I am only seeing the ability to scale both length and width simultaneously? So how do I or am I able to scale either just the length or width of the original merged drawing independently?
Old 01-06-2004, 03:29 PM
steveald steveald is offline
steveald is on a distinguished road
I am not familiar with BobCAD, but I had a scale problem in the past that I solved by scaling the objects prior to exporting rather than after importing into the CAM software I was using at the time. Just a thought, although you would think there would be the ability to scale individual axis in BobCAD. Good luck with it.
Steve
Old 01-06-2004, 03:49 PM
awm awm is offline
Thanks Steve and yea I also thought of that but in order to have the drawing at 1:1 in BobCAD I had to scale the original drawing down to microscopic size. And when that occurs it then doesn't accurately import the drawing into BobCAD A vicious cycle for sure but thanks for the input and I will keep at it as we all do
Old 01-06-2004, 04:22 PM
buscht's Avatar
buscht buscht is offline
awm, You might get a quicker response at the Bobcad forum. I read a post where the Bobcad guy told someone to post there as their technicians monitor that forum.
T
Old 01-06-2004, 04:31 PM
awm awm is offline
Very true buscht, guess will try to post it over there as well just from what I have seen (read) they are not always the quickest to respond but I guess if I don't post they cannot respond right? Thanks for the suggestion
Old 01-06-2004, 05:31 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
T
They monitor this forum as well and most of the moderator are Bobcad users.
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 01-06-2004, 06:53 PM
Kookaburra's Avatar
Hi AWM,
I will have a look if there is a way to do it via geometry. There is a way you can do it so your g-code scales correctly. In the nc-cam setup under coordinates there is an area where you can scale the output coordinates for the g-code.
EG: If you have geometry that is a square 4" x 4" on screen you can leave the geometry as is, but get a scaled g-code output.
Under the setup _ coordinates_scale, if you set X : 1.0 , Y : 0.5 you will get g-code that will contour a X4" x Y2" square. If you set the scale to X : 0.75 , Y : 0.75 you will get g-code that will contour a 3" x 3" square. If you then want to transfer that into geometry for your saved records you can highlight all of your g-code text and under the nc cam edit function select geometry from g-code and you will have the scaled item. I will try to figure out a way to reduce the amout of steps for this process. I will also try to see if it is possible to write a script to perform the function you want. If I can do it via script I will make it available up here for everyone with compliments from the BobCAD world wide staff.
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 01-06-2004, 08:43 PM
AWM, there must be something wacky about the units you are using in one program versus the other. Check that you are using the same size units (mm, cm, m, or inches, feet) in both programs.
There is also never any need to draw in any program with any scaling factor except 1:1 When you say the part becomes microscopic in Autocad, this has me suspicious. All part proportions are relative..........
Old 01-07-2004, 12:01 AM
Konrad's Avatar
Konrad Konrad is offline
Konrad is on a distinguished road
CNCadmin, this ist what CNCdude told me ???
Konrad
CNCdude
Machinist
Offline!
Referred: 0 users
Technical support for BobCAD-CAM software
(Post #16 )
Dear Konrad,
This is not the right forum for BobCAD Technical Support. My technical support personel do not monitor this forum for support issues. I monitor this forum because I care about your success with our software. Please contact support directly at 727-489-0003. We will be happy to assist you in any way we can.
Thank you,
CNC dude
Old 01-07-2004, 12:21 AM
CNCadmin's Avatar
Site Owner
Konrad
CNCdude
Machinist
Offline!
Referred: 0 users
(Post #16 )
Dear Konrad,
Thank you,
CNC dude
CNC dude is right this is not a technical support site or a forum for support for Bobcad software, but it is a site for people with technical questions to get answers. The original post is not a support question, but "more of a how do i" question.
Administrator
www.rfqwork.com
Old 01-07-2004, 11:11 AM
Rest easy, Paul. 10 replies here, none over there
G-Code to DXF WayneHill OpenSource Software 81 08-19-2009 10:54 AM
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 01:51 AM
AutoCad 2000 DXF Question Holmes_ca Autodesk Software (Autocad, Inventor etc) 8 01-19-2005 06:50 PM
basic machining question senor J. General Metalwork Discussion 1 12-07-2004 11:48 PM
DXF question? CNCadmin Carken Products (Deskam, DeskCNC etc) 3 05-07-2004 02:35 PM
