Old 09-01-2006, 11:54 PM
Adobe Machine Adobe Machine is offline
Adobe Machine is on a distinguished road
Manual to CNC Lathe conversion..Pictures
I bought this Pratt Whitney Type C Tool room lathe in the early 70's at a US Government auction.The lathe had never been used, had no tooling, chuck, motor or belts, but was damaged as the shipping pallet had wasted away and broken or bent all the controls in front. At the time I was going to college on the GI bill,working full time at a machine shop and raising a growing family.Having neither the time or resources to equip or repair it, sat for another 4-5 years. In fact I almost went broke paying for transport to my garage, as this "little" 12X30 lathe is 3200 lbs !
Sometime after graduation, suffering through my 1st layoff in the GREAT Aerospace industry, I did repair the broken handles,clean,install a 10hp, 2 speed motor and belts and started doing prototype work, sub contract and small lot pieces. We quickley found out that this is a very accurate, smooth lathe, with a very good finish capability.My customers were happy.
We have kept good care of the lathe over the years, I did not allow any other employees to operate, never used a tool post grinder on it, did only prototype or small pieces. Got tired of the horrible Government green paint and refinished with a 2 part epoxy Grey in the 80's..have touched it up, but the paint is still holding up.
I believe the machine was manufactured in the mid 1950's as one thing that I got with the lathe is an updated wiring diagram dated 1952 ( The paper is parchment, really old) The auction reciept did not list a year, only model and ser.#. Wow that makes it 50 yrs old or so..!
The gearedhead has 32 speeds ( with the 2 speed motor) has its own oil filter and oil pump. I did have Caterpiller ( Empire Machinery,Phoenix ) do an oil analysis on the gearhead oil...came out real good.. no metal, bronze, chrome or other suspect metals in any excess amounts .
The decision to retrofit to CNC was easy.Due to an accident I'm in a wheel chair and cannot stand in front of a lathe very long to build goodies (blower systems, pulleys, contours, threading etc) very long. I have a good Le Blond 17X60 manual lathe if needed, in fact will be used to build parts for the Pratt Whitney.
Getting with the program to retrofit:
1)Clean up and spot paint the old girl
2)Remove the apron drive shaft,threading feed rod compound acme screwand nut, along with the taper attachment.
ID:	22128   Click image for larger version
ID:	22129   Click image for larger version
Old 09-02-2006, 01:27 AM
Here are the items purchased and delivered so far. Machine Tool camp servos with US Digital encoders, ( 672 oz/inch) Desk CNC Motion Control Card and their Software,encoder cables with a US digital encoder for the spindle RPM.I chose Machine Tool Camp as I used their program for my 3 axis Tree Mill retrofit,have had NO problems, and Scott's help in the electronics and software was invaluable. I'm also using Vector 3d CAD/CAM from IM Service that matches Desk CNC, and I have become comfortable with the system, even being a complete computor KLUTZ.Fred Smith and Jackies help have kept me sane learing the system.
Rockford rolled Ballscrews and double nuts were my choice for both axis, will machine the ends myself on my manual Le Blond lathe.Taking my own advice, I also purchased the Fixed angular bearing mount for both the Z and X axis, will use one simple bearing mount for the Z axis, but made the mount for the X axis.
I made the large timing pullys ( 72 teeth) out of 6061 Alum and had them hard anodized, bought the 10 teeth smaller ones which will give me a 7.2 to 1 ratio..the servos are rated @ 4200 rpm, but will reduce to 3500 rpm. This gives a final G00 rapid of 90ipm with the 5tpi ballscrews, which is a lot faster than I can think at this age.(actually that means the entire Z axis transverses in less than 30 seconds) Misc electronics will include 2 electronic relays to control coolant and a four position tool changer that is in "design" stage..for now my goal is to construct the 2 axis,with no backlash or problems and use the lathe in CNC untill I'm comfortable .Then possibly a 3rd axis and tool changer.
Not pictured is the 12 amp 70 volt power supply ( Machine Tool Camp) and the electronics cabnet and misc wiiring and electronics.
Building the front x axis simple bearing mount:
1st picture. Using my PowerMatic Verticle automatic band saw to cut the 6061 t-6 material. ( If I concentrate this saw will cut accuratley to .030-.050 and saves a lot of machine time..)Then using my Retrofited 3 axis Tree Mill to "square "the part and machining the male and female bosses . The bearing fit is tight slip fit ( used oil and both thumbs to push in ). Also the 4 mount holes and counter sink.
You will notice the mounted manual oil ( way) pump. I drilled and tapped fittings for the Z axis carriage,and the compound slide,in addition both Ball nuts will be lubricated by this system.
Next will be the rear bearing ( fixed angular ) mount.
ID:	22139   Click image for larger version
ID:	22140   Click image for larger version
ID:	22141   Click image for larger version
Old 09-02-2006, 01:37 AM
Here are the rest of the pictures for the front x axis bearing mount
ID:	22144   Click image for larger version
ID:	22145   Click image for larger version
Old 09-02-2006, 01:20 PM
Machining and assembly of the rear X axis fixed angular bearing mount.
The real problem here is to establish a true center line of the compound ball shaft both vertical and horizontal. There is a machined hole that had located the rear compound bearing for the acme rod, and also located the the taper attachment. The center line of that machined hole will be the center line of the ball screw. I turned a "plug" that fit in the hole, (1.125), then cut, surfaced , drilled the 4 mount holes and counter sunk for allen bolts on the spacer block.
Mounting the spacer block on the lathe, I used my depth mic from the top of the bearing block ( machined) to the top of the compound ways ( machined) then to the top of the plug I just made, added that together plus the radius of the plug and I should have centerpoint ( should) I measured three times and had a friend of mine who is a very good machinest come over to the house/shop with his depth gauge and his answer was withen .0003 of mine.
This gave me the depth for the fixed angular bearing mount, the center of the bearing block is the center of the bolt pattern(horizantaly)
Using Vector Cad Cam made a short pocket program, but added .015 to the width of the pocket for a little "fudge factor". and also drilled the 4 holes (oversize by .020) for the bearing mount.When I know everything is in good alingment,then I will install 3/16 locating pins on both the spacer block and the fixed angular bearing mount and correctly torque all of the fastners.
The reason I left some fudge factor is due to "stack of tolerance",which believe me ,has gotten me in trouble before.( I.E. assuming everything was perfect and would fit just right )I'm not discounting that we may have to use shims, or surface the fixed angular bearing mount.
Next will be the mount for the double ball nut on the compound, then to machining the ball screw and a very small knurled "positioning" knob on the front of the machine for the X axis.
Adobe ( old as dirt)
ID:	22162   Click image for larger version
ID:	22163   Click image for larger version
ID:	22164   Click image for larger version
Old 09-02-2006, 03:42 PM
fkaCarel fkaCarel is offline
fkaCarel is on a distinguished road
Nice. Do I see the leightweight pulley on picture #1? Big reduction?
Old 09-02-2006, 04:50 PM
yes ,but the belt is not the correcrt one..also you can see the tensioners, as I use two per belt to tension and to keep the correct "wrap" on the small pully. By the way how is your conversion going ?any pictures yet ?
Adobe (old as dirt )
Old 09-02-2006, 05:09 PM
Where did I say I was doing a conversion? I already did a CNC mill and software with a friend in 1986. I can only be accused of updating. But my main fixation at the moment is threading.
Old 09-02-2006, 06:01 PM
yes the software I have does have a threading program, all you do is fill in the length etc, and immediatly the G code is written.This covers metric, us and if you need an odd ball ( like .472X 32) you can build that type also.
O, and sorry I thought you were building a cnc lathe.
Old 09-02-2006, 06:15 PM
I worked on a CNC lathe. Threading was just fantastic at 800-1000rpm, it is the big difference. I also did worms with circular intrapolated starting points. But, what is the reason for the big reduction?
Old 09-02-2006, 08:33 PM
Its just 7.2:1. This also helps increase torque, which I need as the spindle is limited to 2000 rpm .At axis servo speed of 3500 rpm, this calculates to 90 IPM. The total Z travel is only 30 inches, so it could go from Z 30 to Z0 in 20 seconds which to me, is just real fast. Any higher ratio,it would gain speed and lower torque. Also, if I do not like the axis performance,it is not much of a job to make another pully. Thanks for your reply
Old 09-02-2006, 09:58 PM
Switcher's Avatar
Switcher Switcher is offline
Switcher is on a distinguished road
Adobe Machine,
I noticed that your new thread here is posted in the "Test Forum".
You might want to move to a more specific catagory. I'm not 100% sure, but I think that all the post in the "Test Forum" are deleted after a short period of time.
Jerry
Old 09-02-2006, 10:12 PM
er, your right.how do you switch to another forum ? and thanks.
Adobe (old as dirt)
