Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Digitizing and Laser Digitizing
Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here!
Old 07-26-2006, 03:35 PM
mikegasman's Avatar
mikegasman mikegasman is offline
mikegasman is on a distinguished road
Cheap home made Touch Probe.
here’s my home made probe wanted something to play with but with out the cost.
It’s made out of MDF water pipe pan head screws springs wire connecters.
Works ok for what it is.
ID:	20359   Click image for larger version
ID:	20360   Click image for larger version
ID:	20361   Click image for larger version
ID:	20363   Click image for larger version
Old 07-26-2006, 03:41 PM
truman truman is offline
truman is on a distinguished road
Hi I was just wondering if you could explain how this works the probe I meen this is really interesting
thank you
Old 07-26-2006, 05:54 PM
mikegasman's Avatar
Here’s some more pics let me know if you need more or what you want to know about it.
ID:	20372   Click image for larger version
ID:	20373   Click image for larger version
ID:	20374   Click image for larger version
Old 07-26-2006, 06:24 PM
teebee teebee is offline
teebee is on a distinguished road
Are You using it only verticaly? I mean when probing, do you only go to the probed part from top and measure the vertical coordinate when one of the contacts is opend, or are You running the probe along the part?
How does it behave on skew surfaces? What is the raster used for probing the wrench???
I know.. tonns of questions, but this is a realy interesting project. Congratulations, looks realy impressing to me.
Old 07-26-2006, 06:45 PM
those are great pictures what software are you using with this setup
Old 07-26-2006, 10:55 PM
mikegasman's Avatar
I use mach3 to run the probe and my machine. The digitizing wizard in mach3 works good
when probing the writing on the wrench it comes down in the z axes and records the position
that’s all I’ve done with it so fare it will activate going in the XYZ position.
Was just sharing what I made with every one who mite want to play with a probe but don’t have the money for it or the time to make a fancy one.
Old 07-26-2006, 11:21 PM
paulC paulC is offline
paulC is on a distinguished road
Brilliant. There I was thinking about using PC board and bearings.
Will use your design just replacing mdf with plastic.
Paul
Old 07-27-2006, 12:12 AM
toneV8 toneV8 is offline
toneV8 is on a distinguished road
Also home made Touch Probe.
http://www.indoor.flyer.co.uk/probe.htm
Old 07-27-2006, 12:24 AM
chronon1's Avatar
chronon1 chronon1 is offline
chronon1 is on a distinguished road
It looks like you made 10 passes to get that crude image - but its not bad considering it came off the side of that monkey wrench .... And that's pretty fine lettering .. probably most uses of your probe will be on larger scale and will give you better ...
I don't know what the purpose of this thing is other than to make an image .. it seems like rather crude type of 'scanner' like a paper scanner (2D) but it's a 3D scanner - so mach3 gives you that image and then you can recreate it ... So it's for scanning in something ot get a rough plot which you can then mill and produce something almost as good as the original .. ?
Old 07-27-2006, 12:57 AM
turmite turmite is offline
chronon1, these type probes can be used to pick up the edges of a part, fnd the center of a hole or scan a part in 3d giving a point cloud that can then be manipulated into a full 3d image so a gcode program can then be made from that. Reverse engineering is the largest use for these type probes.
Mike
Old 07-27-2006, 01:09 AM
chronon1's Avatar
Sounds pretty cool - beets starting from scratch each time .. ill bet china nad japan have a whole lot of these probes, in fact i'll bet anytime something new comes out, the SOP in a Chinese plant is to get the good ole probe out and begin pumping widgets !
(Hope not too many Chinese are reading this , if so , don't take too much offense, I lost my IT job recently to Bangalore India--- )
When you say point cloud and manipulating it .. is that something Mach does or you have to go in manually and have fun line by line ?
Old 07-27-2006, 02:24 AM
sendkeys sendkeys is offline
chronon some of the best point cloud software is made in china i wonder why :P hehe Saw the new solidworks2007 going to have point cloud support
http://files.solidworks.com/News/scanTo3D/scanTo3D.html
[IMG] code is Off
