Old 07-20-2006, 05:06 AM
Greolt Greolt is offline
Greolt is on a distinguished road
Way oiling systems
Can anyone tell me about what they have done re setting up way oiling syatems.
I've seen on pictures of Bridgeports etc oiling systems built on.
Is there an after market device or has any one made up a system?
I am converting an X3 and while at it I would like to do something about it.
Thinking that keeping ways oiled is even more important on a CNC'd machine than manual.
Old 07-20-2006, 07:21 AM
Bubba's Avatar
Bubba Bubba is online now
Bubba is on a distinguished road
On my mill/drill, I cut some "Z" groves in the ways and drilled oil feed holes in accordance with some information that I found in a machinery rebuild book a friend lent to me. Then using 5/32" ID tubing and quick connect fasteners that I found in MSC catalogue, along with a manual pump from Enco, fabricated up a system. At that time, I "attempted" to control the amount of oil going to the various parts by making my own orifices at the the attachment point using different sized drills. Oil lines were also fed to the ball screw nuts to keep them lubircated. At the pump end, I made a simple log type manifold to feed all of the various lines. You can get the idea from a couple of the pictures in my tag line. So far, the system has worked well (couple three years) and think it is far better than previous attempts to "squirt" some oil on the ways when I remembered to:})
Country Bubba
(Older Than Dirt)
Old 07-20-2006, 07:28 AM
There are companies like Bijur that have complete systems that include metering devices at each lube point, and simple pumps , it is important to have the correct system balance to achieve the right pressure, otherwise one point gets all the lube.
(Kenneth Graham )
Old 07-20-2006, 07:31 AM
ngr1 ngr1 is offline
ngr1 is on a distinguished road
Way oiling.
I was able to derive some ideas from this great site. http://www.chicobritish.org/CNC/
I have also read were people have use One-Shot oilers to force the oil into the passages.
Norman
Old 07-20-2006, 06:35 PM
Thanks peolple for your pointers
Enco have a couple of one shot type pumps in their catalogue.
Have to have a hunt in Aus. now that I know what is available.
Old 07-20-2006, 10:39 PM
festess's Avatar
festess festess is offline
festess is on a distinguished road
Here's an example of the metering valves mentioned earlier in the post. It's a Mcmaster and Carr part number so that probably doesn't do you much good in Aus. but it gives you an idea. Something like this will keep all of the oil from going on the path of least resistance so everything gets oiled. Part number 2293K13 page 2046 of the online catalog.
Old 07-21-2006, 04:58 AM
Thanks for that Festess.
Unfortunately McMaster doesn't want anything to do with us reprobates from down under
Old 07-21-2006, 09:59 AM
TPPJR TPPJR is offline
TPPJR is on a distinguished road
Here is what I did to my RF-45. Works pretty good, just wish that I had known about the pattern that should have been cut into the ways to help with the oiling. It works good but bugs me to know that it could be better, and no I am not taking it apart to fix it!! I will though if I ever need to tear it down for any other reason.
http://ImageEvent.com/tppjr/rf45dove...l/oneshotoiler
It uses all Bijur meters, manifold and pump to manifold hose. The meters not only meter the flow they also have check valves in them to prevent back flow. The way fittings are press on swivels from Mcmaster Carr and I use a automatic one shot for the pump. I got the Bijur stuff off ebay (for a heafty sum). I had to buy several kits since they would not break up the auction but I could not find them anywhere else. I know I still have one maybe more sets if anyone is interested.
Thomas
Old 07-22-2006, 03:32 PM
Walt@SGS.Inc Walt@SGS.Inc is offline
Walt@SGS.Inc is on a distinguished road
Has any one thought of going to Bijur for pumps and legris for push on fittings.
It is best to get a catalog then order what you want. Metering valves at each
lub point and push together fittings in case you get something wrong.
Manual or electric pumps are available in many sizes.
Regards Walt...
Old 07-22-2006, 08:00 PM
Ron111 Ron111 is offline
Ron111 is on a distinguished road
Greolt,
Dead Nuts post has a couple of shots on a harbor frieght mill. Just one more piece of info.
http://www.cnczone.com/forums/showthread.php?t=19868
Ron
Old 07-22-2006, 10:14 PM
Ron I like what Dead Nuts has done.
Still hopefull of finding a one shot type manual oiler off an old machine or such
but if I can,t then his simple system will be plan B
Old 07-24-2006, 08:19 PM
Factory Guy Factory Guy is offline
Factory Guy is on a distinguished road
We have a couple of lube pumps on ebay right now. They are Lubriquip EO-1 and a EO-3. They are just the reservoir and pump. However, I do have access to a grave yard of old machines that have manifolds and metering blocks. One of these might get you started tho. Hope this helps.
