Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 06-14-2006, 04:04 PM
la_coterie la_coterie is offline
la_coterie is on a distinguished road
Skate-o-rail (patent!)
Hi All,
I've been lurking and talking onboard bits of various designs, In particular
http://www.terry-is.f2s.com/future/l...g/linearb.html
although I've used the generic design some years previous.
This uses 60 x 8mm and 25 x 10 for the bearing holders, the bearings being 19 x 7 x 6 shielded. You'll probably notice that its in steel, I guess it would work as well in aluminium and be much quicker to machine.
Do you know how long it takes to chain drill that lot? I don't I've a cnc mill lurking in the corner of the barn There's no reason why you couldn't do it with a windy handle mill (manual) if the sole objective is to save money. Well I have to save money I've spent it on a cnc mill
ID:	18914   Click image for larger version
Old 06-14-2006, 06:34 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
They look really good, with a cnc machine you can make them in alumn. look pretty easy to produce also.
Old 06-14-2006, 08:29 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
thats a very nice and solid piece, I can't wait to see it assembled
Pablo
Old 06-15-2006, 02:46 AM
Well I try to adhere to the KISS principle Keep It Simple, Stupid! and as many bits the same as possible. For those skates there's only 3 different bits, yeah OK each bit isn't particularly easy...
The joining rail will be replaced with an ali upright when in action and maybe the sides also if I find some suitable ali, I'm not so sure about replacing the bearing holders with ali as I think there's a chance they could crack depite only being 34mm long, the weak point is where the bolt goes through.
I think the full assembly is a few months away yet but when anything significant happpens I'll post some pictures.
Thanks for the interest peu
Old 06-15-2006, 12:54 PM
RepairmanSki RepairmanSki is offline
RepairmanSki is on a distinguished road
I have been lurking here awhile myself and reading and reading and reading...
When I opened that first pic I literally said "wow." That looks like something I could put my confidence in. Are you planning to make the specs available or manufacture yourself for sale? Either way an excellent job and something I'll keep tabs on.
edit: spelling
Old 06-15-2006, 02:49 PM
High Seas's Avatar
High Seas High Seas is offline
Nice move --integrating the bearings/car and toothed belt drive (in the cad). Will the final bits be belt driven too?
Jim
Old 06-15-2006, 04:18 PM
Hi repairmanski,
Well I guess I could make them for sale though then I don't think that they'd be any cheaper than IKO and the like, maybe if I jigged up proper and stacked a set at a time...
I'll post a dxf & dwg in the next few days - If you've the equipment to make them I've no problem with you doing that for personal use
and yes, Highseas, it will use elastic bands for motion, oops sorry,engineering talk only I mean synchronous belts, though I'm still designing the gearing as a direct drive will give in exces of 200m/min and its not likely to have much grunt, oops there I go again, I mean power.
I'm working on a 1250mm work area, but it might grow if I have enough metal
ahm back to the drawing board...
Old 06-16-2006, 01:05 PM
Ok,
I've had a bit of time to spare & cleaned up the dwg file and made a dxf so if you're any good at chain drilling and using a file... take a look
Old 06-16-2006, 04:35 PM
joecnc2006's Avatar
www.joescnc.com
I opened the drawing file and when i rotate the view -90 degree's (the one in the middle which shows the profile of the 3 bearings on the pipe) there does not seem to be enought room for a suported rail? I think if you changed the bearing contact points to 12:00, 4:00 and 8:00 for example this will allow for the weight of the gantry to ride at the 12:00 point and the other two to stop any lateral movement, and the bolting plate for the gantry will be in a horizontal possision.
Hope this makes sense.
Joe
Old 06-16-2006, 05:05 PM
WilliamD WilliamD is offline
WilliamD is on a distinguished road
I really like this design, much like the design on Dave's site buildyouridea.com. But the one on his site provides for adjustement on the bearings. I think that idea could be incorporated easily enough with this design. I love this design, seeing how you just need a CNC mill, and not a foundry setup. I think this will definetly be the ticket for my CNC router. Great job!
Edit: Also, would their be any disadvantage to 3 sets of bearings? Too much friction? I would think that three adjustable sets would be extremely ridgid! I concur with Joe though, I will have to switch it so the weight rides at 12 o'clock, and I'll have to have a supported rail. My gantry will be all steel and weigh quite a bit!
Old 06-17-2006, 01:56 AM
smoker smoker is offline
smoker is on a distinguished road
eccentric bushings for skate bearings
Nice setup.
Does anybody know if eccentric bushings exist for skate bearings?
and where to buy them ? :-)
David
Old 06-17-2006, 03:11 AM
Joe200che, The design is, um, designed to be used in the plain shown, that is with the support at the side. There is enough room drawn for a max 12mm wide support, but that's with no clearance! I plan on using 10mm dia pillars as found necessary.
Skate-o-rail is supported sideways so that it can have a cover over it as shown in the drawing cross-section.
Of course you're free to hash it about for your purpose as you see fit...
WilliamD; Skate-o-rail does has means of adjustment, the bottom 2 bearing mounting holes are slotted and in this design it will accomodate either 1 inch or 25mm bar/tube.
I guess you could use 3 sets each side but I really don't think its necessary, The sensible thing is to keep weight on the gantry to a minimum as "porky" gantrys will cause problems cutting sharp corners and excess strain on the drive train.
Good feedback - carry on
Old 06-17-2006, 11:46 AM
Ken_Shea Ken_Shea is offline
la_coterie,
Sice you had already given permission to use your design for personal use I thought you or others might find the assembly drawn in solids useful.
It is in .stp format, If any one need it in another format for loading let me know.
  #14   Ban this user!
Old 06-17-2006, 12:18 PM
Hi ken_Shea,
I'd like to see that, can you do anything that I can see in autocad please
Old 06-17-2006, 12:39 PM
la_coterie,
I can export to the following additional formats, any of these importable by AutoCad ?
.xfa
.3dm
.igs
.stl
.sat
Ken
