Old 11-19-2003, 09:33 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
Version 19 tip and tricks
Post your Bobcad ver19 tip and tricks here!
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 11-20-2003, 04:33 PM
CNCdude CNCdude is offline
Support Member
CNCdude is on a distinguished road
Adding a hot key for UNDO
TIP#1:
To add a ctrl+Z do the following:
1. Select the Special/NC CAM menu and then choose RECORD SCRIPT and then MENU CONFIGURATION from the sub-menu.
2. Under Menu Type enter CAD.
3. Under Number of Menu Levels check #2.
4. Menu level 1 needs to be set to 1.
5. Menu Level 2 needs to be set to 5.
6. Key: Z (not the #2...use the letter Z)
7. Check the Ctrl option and un-check Alt.
8. Select EDIT and you should be good to go.
CNC Dude
Old 11-26-2003, 10:42 AM
cely's Avatar
cely cely is offline
cely is on a distinguished road
Pi in V19 scripts
The function Pi is not defined in the V19 scripting language.
A temporary work around is to add the following at the beginning of the script---
Pi=3.14159265358979323846264338
Poor planning on your part does NOT constitute an emergency on my part!
