Old 03-24-2003, 07:16 PM
Vrogy's Avatar
Vrogy Vrogy is offline
Vrogy is on a distinguished road
Necessary equipment for CNC mini-mill?
I'm looking into the cost of getting a CNC mini-mill up and running, and I'm wondering what accesories I should get with it instead of finding out after I order it that I need additional parts...
Here's what I've got on my list of stuff to buy so far:
a Harbor Freight mini-mill-----------------------------------549.99
Harbor Freight Mini Milling Machine
the mini-mill starter kit at littlemachineshop.com------74.95
Starter Kit, Mini-mill
the starter kit includes a clamping kit, parallels, 1-2-3 blocks, a edge and center finder, and a t-slot cleaner.
I also think I'll need a dial caliper, a dial indicator, a magnetic dial caliper holder, and one of those little steel rulers...
I'm wondering what other stuff I'll need, especially the CNC equipment. Can anyone point me in the right direction?
http://flickr.com/photos/vrogy/
Old 03-24-2003, 07:51 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
1)-Well, you will need 3 stepper or servo motor's.
2)-Steel or aluminum plates to mount the steppers on.
3)-3 qty servo or stepper drivers
4)-3 qty belts
5)- 3 qty pulleys
6) NC software
7) CAM software
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 03-24-2003, 08:20 PM
CNCadmin's Avatar
Site Owner
Here is some of what you need. That is a 25v power supply to run 3-7A stepper drivers.
Administrator
www.rfqwork.com
Old 03-24-2003, 08:23 PM
CNCadmin's Avatar
Site Owner
Here is how what is going to hold the x stepper motor. I will post more pic as assemble this machine.
Administrator
www.rfqwork.com
Old 03-25-2003, 12:51 AM
Vrogy's Avatar
servo motor...could large size RC servos be used, or is there a need for lots of torque? Also, has anyone ever put together a how-to site of sorts?
Old 03-25-2003, 12:56 AM
CNCadmin's Avatar
Site Owner
NO r/c servo's will not work, you need NEMA 23- 34 stepper motor's 100-300 in oz.
Administrator
www.rfqwork.com
Old 03-25-2003, 12:57 AM
CNCadmin's Avatar
Site Owner
That is one of the reasons, I started this site, that is site is for LOL
Administrator
www.rfqwork.com
Old 03-25-2003, 02:06 PM
HomeCNC's Avatar
HomeCNC HomeCNC is offline
HomeCNC is on a distinguished road
Vrogy, Check out my web site. I have my entire learning about Homecnc documented there. Start at the top and read each link.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 03-25-2003, 09:35 PM
CNCnUtZ CNCnUtZ is offline
CNCnUtZ is on a distinguished road
well I would definately get a quick change collet set like this.......
http://www.grizzly.com/products/item...9&site=grizzly
To keep from having to wail so much on the drawbar of the spindle to release whatever you are using in the spindle at any given time.
And I would suggest you get a rotary table to do arcs and circular cuts....littlemachineshop has a decent selection and competeitive prices
You should also check out http://www.wttool.com as they have alot of good prices and just about anything youd need in accessories.
Also http://www.reidtool.com for a large selection of things from springs to ballscrew assemblies in case you want to convert you milling machine to ballscrews for extra precision when you convert it to CNC.
I suggest that you look for a 2 inch dial indicator /magbase holder kit at wttool.com as it really makes it easier to use considering you have 2 inches of travel at a time to use in measurement.I think they have a decent set for around $30 -35.
When you purchase drives for the steppers/servos, go with geckos, as they are the best you can buy for the money, hands down! And the guy who owns it, Mariss, gives A+ customer service for his products and is a very, very nice guy to deal with.
Shop ebay for a power supply in the range of your requiremnts, as they are quite expensive if you buy them commercially.
I purchased nearly everything to convert my sons mini mill to CNC.......including the preloaded ,O backlash ballscrews that I fitted it with.
I think I spent in the range of $1200 including the Grizzly mini mill to get a very precise, small hobby CNC milling machine that can cut nearly as fast and precise as my +$4000 converted RongFu mill.
Good luck
Old 03-26-2003, 01:58 AM
Vrogy's Avatar
ok...I think I'm looking at outfitting a mini-mill for CNC before I do a lathe, and I've seen a difference pop up sometimes--3MT vs. R8 tapers. Which is best, and why?
Old 03-26-2003, 10:33 PM
R-8 sized accessories are more commonly found everywhere they sell milling accessories.
MT3 are a little harder to find.
The only place that sellls an R-8 spindle mini mill is Harbor Frieght and Ive heard quite a few less than desirable things from various people about the quality of the machine, and mostly the poor customer service.
BUT.............You can buy a MT3 mini mill and convert it to R-8 if you so choose, by purchasing a spindle convertion kit from http://www.littlemachineshop.com for roughly about $40-45 dollars, including the toolkit required to make the removal of the original spindle and insertion of the new one, as simple and painless as possible.
I would recommend getting a Grizzly as I own to of them myself. But aside from that, I hear that they are usually of a better quality than other places that sell these" Sieg "type of mini mills.
And that is the reason why I chose to spend the extra money on the Grizzly models.
You pay a little more, but IMO, its worth it in customer support that you recieve ,alone.
Id also Like to add, that these little mills, given you dont "skimp" on the parts to do the convertion to CNC, are rather accurate. Almost as accurate as my big mill and ,by far, much cheaper.
In this hobby(as a friend of mine stated once).....the more money you throw at it, the easier it becomes.
Expensive little hobby to get into indeed!
Old 03-27-2003, 12:38 AM
WOODKNACK's Avatar
WOODKNACK WOODKNACK is offline
WOODKNACK is on a distinguished road
Just a note. You can buy the mini mill thru Homier! its the same as HF. Called the Speedway like the lathe. It has a r-8 spindle. I have one and like it. Plus you cant beat the price $399!
What size steppers for Grizzly mini mill? Mini Miller Benchtop Machines 14 07-18-2005 12:45 AM
New and need sugestions on a mini mill 691175002 Benchtop Machines 2 05-23-2005 02:09 AM
Capabilities of mini mill @ $2500 jl123 Benchtop Machines 17 05-14-2005 10:59 AM
New to Mill and CNC - Can you mix a Mini and Micro Mill Sherpa Benchtop Machines 2 09-09-2004 10:36 AM
possible cnc conversion on homier mini mill WsW-WYATT Benchtop Machines 3 03-27-2004 08:24 AM
