Old 03-08-2006, 01:19 AM
RJ. RJ. is offline
RJ. is on a distinguished road
Sharp Mill retrofit
I finally finished my Sharp LMV retrofit. Mach 2 control, Pacific Scientific AC brushless servos on X, Y and knee. Ballscrews on X and Y. Gas springs on knee.
Regards,
Rick
ID:	15487   Click image for larger version
Old 03-08-2006, 01:34 AM
svenakela svenakela is offline
svenakela is on a distinguished road
Well done!
Are you satisfied with the result?
Old 03-08-2006, 02:07 AM
RJ. RJ. is offline
Well, it's still a work in progress. I still have about .002" backlash in the knee I have to look into. But I am happy to finally have it running. X and Y ballscrews are running well with little to no backlash. I still have dials on X, Y, and knee along with a 3 axis Newall DRO because I am a new machinist-hobbiest, and I still expect to use the machine manually alot while I'm learning.
I would like to take a moment to thank my instructors at De Anza College Department of Manufacturing and CNC Technology for their instruction and help with my project and for teaching me some basics of manual and CNC machining. I have so much to learn. Many thanks to Mike Appio, Scott Wigginton, Larry Brown, Mike Engle, Loren Beall, and especially Chris Newell, without whom I could not have done this project .
First cuts on my machine are dedicated to them. It is the Manufacturing and CNC Technology Department logo. Thank you all.
ID:	15321   Click image for larger version
Old 03-08-2006, 05:44 PM
propclock propclock is offline
propclock is on a distinguished road
sharp cnc ballscrews
I am thinking of doing the same to my sharp mill.
Where did you get the ballscrews? my table is 50" sort of odd ball,
I have only cnc on the knee so far. I used a dc gearbox motor and timing
chain drive . this allows the full weight of the knee to be moved with ease
and feedback is via a rsf glass scale on the knee. It takes a while to settle
but repeats to better than .0001. some dc bias (offset) on the motor makes
up down motion equal and allows for manual operation with a 8" handwheel
Old 03-08-2006, 08:26 PM
RJ. RJ. is offline
propclock,
I got my Hiwin ground ballscrews for X&Y along with the motor mounts from HS&S Machine Tool in Santa Clara, CA. See www.hsands.com and call and ask for John Servin.
They used to do Sharp Mill retrofits, and he had a few leftover parts. I'm not sure if he still has anymore. If not, I have the drawings for the Hiwin parts so you could have some made.
The ballscrews I got came long, and I had to shorten the ends of both the X and the Y. I think they were probably made for the 50" table instead of my 42". Otherwise, the ballnuts fit perfectly in the yoke with some drilling and tapping for fastening screws. I will try to post more details of my retrofit as time allows if there is interest. Otherwise, let me know if you have questions.
Regards,
Rick
Old 03-08-2006, 11:26 PM
RJ. RJ. is offline
At the beginning...
It's raining the day the rigger comes to pick up my mill at the tool dealer, so we wrap it up. It's loaded on the forklift then onto the flatbed truck. Then on the way home.
Old 03-08-2006, 11:40 PM
RJ. RJ. is offline
After acquiring the ballscrews, motor mounts, motors, and drives, work is started to take things apart. I took alot a pictures because I've never done this before, and it's all got to go back together again later.
Started by taking off the X and Y acme leadscrews, loosened the gibs on the table, and slid the table onto a melamine board at the same height by adjusting the knee height. I was surprised how easy it was to slide.
This gets us to the yoke. The stock yoke only references the bore for the bronze acme nuts, but the ballnuts reference the faces of the yoke so I need to machine the faces square to each other and the bore/ mounting flange.
ID:	15343   Click image for larger version
ID:	15344   Click image for larger version
Old 03-08-2006, 11:51 PM
RJ. RJ. is offline
I used an angle iron as a fixture to mount the yoke so I could square the faces to the bores and mounting flange. I mounted the yoke by the flange to the angle iron after drilling and tapping the angle iron. I used a dial test indicator with a long point to orient the bores square to each other and the fixture on a surface plate.
I first squared the faces of the yoke on the surface grinder, then drilled and tapped the faces for the ballnut mounting screws.
ID:	15346   Click image for larger version
Old 03-09-2006, 12:37 AM
RJ. RJ. is offline
Next problem is the motor mounting flanges don't match the motor mounts I have so I need to make adapters. A circular pocket is needed so this will be my first CNC program. Luckily the Haas mini-mill VMC I used has a circular pocket canned cycle.
After I make the adapters I need to modify the Y axis mount for the adapter or my motor shaft will be too short. Last photo is the trial fit of the Y axis motor mount assembly.
ID:	15354   Click image for larger version
ID:	15396   Click image for larger version
ID:	15397   Click image for larger version
ID:	15399   Click image for larger version
Old 03-10-2006, 02:11 AM
RJ. RJ. is offline
Since I'm new to this, I don't know whether I'll need the dials and handwheels or not, so I opt to have no regrets and plan to place dials and handwheels. This requires extending the X, Y and knee shafts. I learn to single point thread on a lathe first. I also learn to mill a keyway and broach a keyway in the dial holders.
ID:	15401   Click image for larger version
ID:	15402   Click image for larger version
ID:	15403   Click image for larger version
Old 03-10-2006, 02:17 AM
RJ. RJ. is offline
I bought a knee mount from www.cncauto.com and both the knee and X axis mounts needed a little massaging to fit the knee at the desired angle and for the mounting adapters and slack for fitting the pulley.
ID:	15405   Click image for larger version
ID:	15406   Click image for larger version
ID:	15407   Click image for larger version
Old 03-10-2006, 02:23 AM
RJ. RJ. is offline
Now for my big moment. I need to machine the left end of the X axis ballscrew which requires a keyway and single point threading the end. I don't want to mess this up or I'll be buying another expensive ballscrew.
First I make a support with a leftover ball bearing so the ballscrew won't whip. Then I carefully machined the end.
ID:	15410   Click image for larger version
