Old 03-05-2006, 11:17 AM
N4NV N4NV is offline
N4NV is on a distinguished road
Vince's BP CNC conversion
I did not want to hijack JD's thread any further. I am starting a conversion of my stepped pulley J-head Bridgeport mill to CNC. At the same time I am converting a Taig lathe to CNC. I got a lot of information from JD's thread and much of what I plan to do will be similar to his. I don't really have a good reason for the conversion other than the entertainment and educational value of the project.
I purchased my mill about 8 years ago for $500. It was pretty worn out. I had to shim the Y-axis gib to get it close to being useable. I could get the slop in the table down to .002, but then it would be tight at either end of the travel. I could get decent result if I locked the table in the direction I was not milling. So, to start this project I sent the table, saddle, and knee out to a machine rebuilder to have them ground, scraped and fitted. No point in starting a project like this if the mill is this worn.
I am not going to install ball screws at this time. The machine rebuilder guarantees I can get .002" backlash when he is done (and less than .0005 slop in the table). I can take care of this with software. If it turns out that I am not getting the results I would like, I can always add them later.
I am really starting from scratch. I found 5 60VDC motors at Triangle machine (on of the places that the "MythBusters" shop). It took about three days to get all the specs, but I think they will work for this project. They have no encoder or shaft for an encoder so I will have to add that. The brushes and bearings were shot on most of the motors. The bearings are standard R10ZZ. I found the brushes at Arrowhead Electric Company.
http://www.carbonbrush.com/brushes.htm
They were about $6 each and it takes 4 per motor. I paid $50 each for the motors, $120 for all the brushes, $40 for bearings and $54 each for three encoders.
The first picture is my mill stripped and waiting for the parts to return from the machine rebuilder.
#2 is boring the hole for the encoder shaft in the end of the motor shaft.
#3 shows the armature before I turned it.
#4 is turning the armature.
#5 is the finished armature.
To bore the hole in end of the motor shaft I mounted the motor in my lathe and centered it as best I could. Then I added power to the motor and used and end mill in the tail stock to bore the hole. I did this before I replace the bearings in case I caused them stress from the procedure. Next I pulled the bearing and turned the armature. After turning the armature you have to undercut the armature sections so there is a little gap between them. I installed new bearings, assembled the motor, installed new brushes and tested them. They all worked great. Today I am going to work on installing the encoder shafts and mounting the encoders.
A word on encoders. I purchased some Renco encoders, but after talking to Mariss at Gecko, I found that they drew too much current. The Gecko’s can only deliver 50 mA to the encoder. These Rencos required 125 mA. I purchased some US Digital E5S encoders that will work with the Gecko 320.
Vince
Name:	Stripped Brigeport.jpg‎
ID:	15237   Click image for larger version
Name:	Boreing Shaft.jpg‎
ID:	15238   Click image for larger version
ID:	15239   Click image for larger version
Name:	Turning Armature.jpg‎
Old 03-05-2006, 04:21 PM
I installed the encoder shaft on three of my servos today. I installed the encoder bases as well. When I ordered the encoders, I got the adhesive base option as the mounting holes in the base would not line up properly. It takes 24 hours for the adhesive to fully cure so I will install the rest of the encoder body another day.
I moved on to my power supply. I found a 120 to 43 volt transformer at Triangle Machine. That should give me 60 VDC after rectification, which is what my servos are rated for. I purchased one 7,500 uF capacitor at Triangle, and a friend had two more. I purchased two 50A bridge rectifiers on eBay. I hooked it all up and found out that the bridge rectifier was made out of compressed smoke . Only two of the terminals were marked, one + and the other AC. I guessed wrong on the other two. I looked up its data sheet on the internet and found the correct way to wire it. It is a good think they came in pairs. The second time nothing dramatic happened. I measured 59.8 VDC on the output of the capacitor bank. I connected one of the motors and it ran great. What is a good value and wattage rating for a bleader resistor for these caps?
I'm running out of things todo. It will be another two weeks before I get the parts back for my mill. I need to get it running to start making things.
Pic #1 shows the alignment tool that you have to buy separately from the encoder to ensure that you have the base centered properly.
Pic #2 shows two motors, one with the encoder shaft installed, and the other with the shaft and encoder base.
Pic #3 shows the power supply hooked up and running one of the servos in the vise.
Vince
Name:	Encoder base.jpg‎
ID:	15250   Click image for larger version
Name:	Encoder shaft.jpg‎
ID:	15251   Click image for larger version
Name:	Power supply.jpg‎
Old 03-06-2006, 09:22 AM
Eric Eric is offline
Eric is on a distinguished road
Where is Traingle Machine located?
Old 03-06-2006, 05:23 PM
Triangle Machine is in San Jose, CA on comercial court, which is off of comercial street. Take 101 to 13th street north, turn right on comercial street, left on comercial court.
Vince
Old 03-07-2006, 05:50 PM
I finished my servos today. Mounted the encoders and a 3/0 Bell box extension to protect the plastic encoders. I am stuck again for now, I ordered three connectors from US Digital to pug into the encoders, but I can't figure out how to attach my cable to them. I might need a special tool. US Digital calls the connectors a finger latch connector. It looks like the audio connector on the back of a CD or DVD drive in a computer. If I have to get premade cables, I'll be another week before I can test the servos.
I received a Gecko G320 today and a cnc4pc parallel port break out board. Once I know that everything will work electrically and I can drive my servos with Mach 3, I plan on updating to the GREX 100 and Mach 4. I will order another two 320's as well.
The machine shop called today and said my mill parts will be ready to be picked up at noon tomorrow. It looks like I will have more to work on for the next couple of days. I ordered an electrical cabinet to mount the power supply, GREX, Gecko's etc. It will come in next week.
I uploaded three pictures that show the encoder electronics and body installation.
Vince
Name:	Encoder disk.jpg‎
ID:	15310   Click image for larger version
ID:	15311   Click image for larger version
Name:	Three finished servos.jpg‎
Old 03-08-2006, 12:13 AM
jdelaney44 jdelaney44 is offline
jdelaney44 is on a distinguished road
Vince, nice job on the encoders!
Your lathe is going to be good for working the screw for the Z drive. Wish I had one that big when I was turning mine down.
Best,
-jd
John Delaney
www.rwicooking.com
Old 03-08-2006, 09:26 AM
Vince.
Try going over to Halted Specialties on 3500 Ryder St. in Santa Clara (408-732-1573). They have tons of small motors over there with encoders. Maybe you can find one with a cable attached that will work with your encoders. If you need any electrical help, don't hesitate to ask.
Where did you send your machine to get reworked?
--Eric
Old 03-08-2006, 05:54 PM
I have been going to Halted almost every day for the past two weeks (along with the trips to Triangle Machinery). They don't have that type of connector. US Digital sent me a PDF that shows how to make up the cable to the connector. You need a special tool, but I think I can do it with some small needle nose pliers.
I had my mill ground and hand scraped at D&L precision, 2821 Fair Oaks Avenue,
Redwood City, CA 650-444-5208. Tell them you heard about them from Vince. Jason runs the place. They are out of the shop about half the time. Most of the big machines they rebuild are done in place. I picked up my parts today. They are still in the back of my truck. I am waiting for my wife to get home and give me a hand. When I get them mounted back on the mill I will post some pictures. Jason said they were in pretty bad shape. He quoted me $700 for grinding the table, saddle and knee. He said it took him two or three times longer than usual to get them flat and square. I guess most machine shops rebuild them before they get that bad. It was another $540 to have them hand scraped and fitted, which included shimming and hand scraping the gibs. I should be good for .0005 now.
Vince
Old 03-08-2006, 11:05 PM
My wife got home and helped me get the trailer out of the garage so I could have room to work, then she left for a meeting. I put the mill together by myself. I uploaded some pictures of the process. It went together a lot easier than it came apart. I still have a lot of little items to install like the DRO scales and the oiler system. It came out great. There is no play that I can feel with the gibs adjusted. Unfortunately, wear showed up in other places. I found that my lead screws are worn in the middle. I have adjusted the half nuts and am able to get .003 backlash, but the table and saddle get tighter at either end of their travel. Without the lead screws, I can push the table or saddle the entire length of their travel with one finger. . I may have to go to ball screws after all. That would really blow my budget and could delay me for a while.
The entire assembly process took me 3 hours. I installed the table twice. The first time I had almost .200” of backlash on the table. I could see it was coming from the half nut in the dog bone. I could not tell exactly what was happening so I pulled the table. I saw that I had applied pressure to the half nut when I installed the lead screw. This pushed it together and allowed the nut to slide back and forth in the dog bone. I reinstalled the lead screw, this time holding the nut in tension. It worked and I the backlash dropped to .003.
Vince
Name:	1on goes the knee.jpg‎
ID:	15348   Click image for larger version
Name:	2scraped knee.jpg‎
ID:	15349   Click image for larger version
ID:	15350   Click image for larger version
Name:	4table next.jpg‎
Name:	5done for today.jpg‎
ID:	15352   Click image for larger version
Name:	6instructions who needs them.jpg‎
Old 03-08-2006, 11:37 PM
.003? I'd give it a go. The software can suck up .003. You can just call it .0015 on the average.
You will have to be careful about transitions from feeding into the cutter and climb milling where the cutter is pulling the work in.
+/- .005 is actually OK for a whole lot of applications. So you are going to be OK for many things. Not sure what you are going to make with it.
When you can afford the new screws it will just get better.
-jd
John Delaney
www.rwicooking.com
Old 03-10-2006, 12:36 PM
CNCfun&games CNCfun&games is offline
CNCfun&games is on a distinguished road
Vince,
If you decide to go for a Ball Screw Conversion, check out Hiwin Corp., I purchased their Bridgeport
Ground Leadscrew Kit w/ Yoke for $950 +$30 (S&H)which was less than most of the Rolled
kits I surveyed in 2003. They are located in San Jose, CA. (408)943-0290
I've been using the screws in manual mode for about 3 yrs. & they are excellent.
On the Z axis retrofit you can minimize your alignment problems if you machine 2 brackets to mate with the stepped reference points on the quill STOP screw mounting Bosses(see picture)
Also are a couple of pictures of the Z Quill/Leadscrew Mtg Block and my Y axis plate.
Regards....Will Smith
ID:	15430   Click image for larger version
ID:	15431   Click image for larger version
Name:	PICT Z-017.jpg‎
ID:	15432   Click image for larger version
Name:	Z axis Quill Block 1.jpg‎
Name:	Z axis Quill Block 2.jpg‎
ID:	15434   Click image for larger version
Name:	Y axis Plate 1.jpg‎
Old 03-10-2006, 07:20 PM
When is a servo motor not a servo motor?
I had a conversation with Mariss yesterday about the various tasks I need to do to get my servos up and running. During the conversation, he mentioned that not all DC motors can be good servo motors. He said on servos the commutator was twisted like a barber poll. I remembered that mine were not. He said a way to tell if it was a good servo was to run it at a very low voltage until the motor is only turning a few rpms. DC motors have something called torque ripple which with cause the motor to turn in a jerky fashion when at low rpm. I started to worry that I might have wasted money on my servo conversions. I could have sworn that the factor rep for the motors told me they were servo.
As soon as I got home I put one of my servos on an adjustable DC power supply. At 1 volt (my motors are rated 60V) it turned too fast to count the rpm. I turned down the voltage to 0.3V. At this voltage it turned at 2 rpm, and smooth as a gear motor. There was no sign of torque ripple. I turn down the voltage as low as my power supply would go, 0.26V and the motor slowed to under 1 rpm. I could just make out the torque ripple. It looked like the second hand on a spring wound watch. I was amazed that it would still turn at such a low voltage.
I looked up information about DC brushed servo motors and found that there are several ways to combat torque ripple. One is by skewing the armature windings. Another is to increase the number of poles or brushes. If you look at the pictures of my motors above, you can see they have both skewed windings and 4 brushes.
Just for the fun of it I hooked up another DC motor I had laying around. When I got to 1V on this 90V motor, it would turn in 15° jumps. A very noticeable display of torque ripple.
Vince
