Old 02-26-2006, 01:36 PM
Konstantin's Avatar
Konstantin Konstantin is online now
Konstantin is on a distinguished road
Casting around the leadscrew possible?
Hello.
Is it possible to cast a brass nut just around the leadscrew to save up on the threading?
Doable?
Konstantin.
Old 02-26-2006, 01:49 PM
Mcgyver Mcgyver is online now
I don't think this will work - the casting will shrink as it cools
Old 02-27-2006, 09:38 PM
ignatz ignatz is offline
ignatz is on a distinguished road
I think you should be able to use a piece of threaded rod as a core in a sand mold and cast threads out of aluminum (Not sure about brass). This is Gingery's method of producing a split nut for his lathe. Have a look at this link:
http://www.backyardmetalcasting.com/lathe3.html
You still need a tap to cleanup the threads.
Old 02-27-2006, 11:16 PM
ViperTX ViperTX is offline
knonstantin....sure it's possible.....but as others have informed you casting do shink about 10 percent or so......is you want to take that approach it's fine....then use moglice on the casting.....
Old 02-27-2006, 11:57 PM
Geof Geof is offline
This thread discusses making a leadscrew nut by casting something around the thread. http://www.cnczone.com/forums/showthread.php?t=15973
It is very unlikely you would be able to cast a brass nut directly and use it in place because of shrinkage. The shrinkage might cause the brass to crack and it would make the nut too tight to move. Also the heat of the molten brass would probably warp the screw.
However, if you cut off a small length of the lead screw slightly longer than you want the nut to be and drilled a hole through it about 0.10" smaller than the root diameter of the thread you may be able to cast a useable nut around this. Removing most of the material by drilling the hole means that the lead screw material would heat up quickly to the temperature of the molten brass and then everything would cool and contract together so the brass would not crack also because the nut material was well expanded by the heat when the brass solidified the shrinkage would come back closer to the correct size of the screw. Then if you cut the whole thing exactly in half lengthwise you should be able to peel the screw material out of the brass to get two good half nuts. If you turned the outside of the cast nut to a smooth finish first you would then be able to mount the half nuts in a slightly oversize housing to compensate for the shrinkage.
I have not tried doing this but it seems a plausible approach.
Old 02-28-2006, 02:16 AM
svenakela svenakela is offline
svenakela is on a distinguished road
Just change the material. Epoxi doesn't shrink.
Old 03-02-2006, 10:43 PM
Kevin Taylor Kevin Taylor is offline
Kevin Taylor is on a distinguished road
I want to try this to re babit the thread's in the split nut's on a old lathe I need to repair oil or neverseese on the screw and a brass or aluminum shim between the two halves any help Thank's Kevin
Old 03-02-2006, 10:52 PM
High Seas's Avatar
High Seas High Seas is offline
svenakela
Epoxy shrinks! Trust me - I've proved it - bummer. BUT you can minimize the shrinkage - add fillers - max 50%, slow the hardening process - cool the mix or use slow hardener, etc. will bring some of the shrinkage back to zero - but still may get some. Cheers - Jim
I suppose in Sweden cooling is easy!
Old 03-02-2006, 11:01 PM
My recollection from a long time back doing babitting (is that a real word) is that oil or never seize is not what you want. The heat vaporizes these and you get cavities in the babitt. We painted the shaft with a suspension of graphite in water and dried it to leave a thin film of graphite which formed the separator between the steel shaft and the babitt; it also left a non seize surface.
Old 03-03-2006, 10:17 AM
vulcom1 vulcom1 is offline
vulcom1 is on a distinguished road
Sounds like an old Atlas. I had the same problem with my half nuts almost wore out. I cleaned the old nuts with a degreaser and cleaned and light oiled the shaft. I used JB weld(epoxy) on the half nuts with a couple of pieces of wax paper between the flanges. Let setup then split. Used them for over a year before buying new. They are expensive to replace on mine for a piece of casting.
John
Old 03-13-2006, 12:49 PM
nikolatesla20 nikolatesla20 is offline
nikolatesla20 is on a distinguished road
Couldn't you simply coat the screw with a thin layer of furnace cement or plaster of paris first, which could then be broken afterward to make room..
Old 03-14-2006, 03:50 PM
Eclectic Eclectic is offline
Eclectic is on a distinguished road
You might want to try a zinc/aluminum alloy: ZA12 or ZA27. The casting temps are MUCH lower, 450-550 C, and the alloy is supposed to have strenght and bearing properties similar to cast iron.
