View Poll Results: If you only have an option of fitting one machine to the gantry, what would it be?
Router 311 80.15%
Dremel 39 10.05%
Something else (please specify what) 38 9.79%
Voters: 388. You may not vote on this poll
Old 02-18-2006, 06:06 AM
posix posix is offline
posix is on a distinguished road
Router or dremel?
Ok, I have a budget and it'll only stretch to ONE machine.
What do I buy? A router or a dremel-type tool? Any other ideas?
I'd want to be able to do PCBs as well as wood (for redesigning and reworking my machine). Working with aluminium is similar to wood so I guess the same machine would cover both?
Is 1000W enough? Variable speed is a must I guess?
If the answer is "router" then what bits can be used with routers? Are they specific to routers?
Old 02-18-2006, 06:25 AM
WhiteTiger WhiteTiger is offline
WhiteTiger is on a distinguished road
Personally I'd go with a variable speed router and not cut too tight on the budget corner. If you plan to ever do any heavy cutting at all the larger spindle and bearings of the router will be a big plus. Paying a bit more to get one with collet capacity larger than the 1/4" on the cheapies will also help by making possible use of larger tooling such as fly cutters.
Tiger
Old 02-18-2006, 06:27 AM
I was thinking of going for the best machine my budget would stretch to so I don't have to buy a new one a few months down then line when it starts showing its weaknesses. So that's why only one is an option. I'd rather have one proper machine than two cheapies.
Old 02-18-2006, 11:15 AM
yukonho yukonho is offline
yukonho is on a distinguished road
Dremel's are absolutely not the way to go. They are weak, and have lots of play and run-out in the spindle shaft.
Probably the best way to go is the RotoZip by Bosch. They have a variable speed model, and the quality of the new Bosch ones is very good indeed.
It sounds like you are going for a smallish router, so the larger 1/2" collet machines would be too big and heavy for your application anyway.
There are any number of bits you can use in your router. The most common one you will likely use on wood is a 1/4" spiral up-cutting router bit, also known as an endmill. The upwards spiral draws the cut chips up and out of the cut preventing clogging of your bit and burning of the material you are cutting.
For your PCB's, you will likely go with a smaller diameter tool, 1/8" or even 1/16" and smaller of course for drilling the holes.
Colin
Old 02-18-2006, 12:19 PM
Ed_R Ed_R is offline
Ed_R is on a distinguished road
I wonder if my machine will handle a router with a 1/2" spindle ? Hopefully!
Those new Bosch Cobas ( 1 hp trimrouter) look pretty cool.
Old 02-18-2006, 12:31 PM
Ok I bought a router. It has 6 and 8mm collets. And I think when the time comes to have something thicker than 8mm it shouldn't be a big problem to make new collets or even fit a drill chuck to it.
Old 02-18-2006, 01:17 PM
ger21 ger21 is online now
You mean the Colt?
Old 02-18-2006, 01:46 PM
yeah that's it, the Colt.
Old 02-18-2006, 07:19 PM
widgitmaster's Avatar
Cool I decided to use a Makita Die Grinder
When i designed my router, I decided to use a Makita Die Grinder #906H, 30,000 RPM dual bearing spindle, easy to repair, made from solit cast aluminum, not plastic! But most of all is was very slender, at 2.8" diameter!
I took the spindle nose casting off and used my lathe to turn it round, to make it easier to clamp on to!
The spindle has a maximum of 1/4" dimeter collet, but I made a reducer for 3/16" and 1/8" shank endmills and bits!
Dremel's are really nice, and not as noisy as my die grinder, but the ergonomic handle designs are impossible to clamp on to!
In my opinion!
ID:	14828   Click image for larger version
ID:	14829   Click image for larger version
ID:	14830   Click image for larger version
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 02-18-2006, 11:23 PM
ViperTX ViperTX is offline
A cartridge spindle...
Old 02-19-2006, 05:02 PM
Just bought the COlt, it bolts up fine to the carriage and its' got a variable speed. I guess I am limiting myself to 1/4 inch shafts and reducers but since my machine isn't all that fast anyway I don't think I'll be spinning many big bits.
Old 02-19-2006, 08:35 PM
kdoney kdoney is offline
kdoney is on a distinguished road
The best inexpensive spindle I've found is the er16 spindle made by Sherline. I bought two and both had less than .0005 runout 1/2" from the collet end. Certainly these are not for hard work but if you have enough time and are looking strictly for precision, it can't be beat for the price. Cheap speed would be a mini mill head from littlemachineshop.com with some work. Never a dremel.
  #13   Ban this user!
Old 02-19-2006, 08:37 PM
Does the er16 spndel do well with router bits? I'm cutting wood almost exclusively and that usually requires a higher rpm due to the bit geometry.
  #14   Ban this user!
Old 02-19-2006, 09:44 PM
Slow would be the keyword. You would have to lessen the preload and the precision a little, but up to a 3/8" shaft router bits could be used at 10k. I think the pcb's would look tighter with the er16 and precision cutting of aluminum would be best served with the Sherline.
  #15   Ban this user!
Old 02-20-2006, 10:21 AM
Jason Marsha Jason Marsha is offline
Jason Marsha is on a distinguished road
Other than my DW610 router (all metal) I would like to try the Kress 900 watt. It seems to be quite popular in Europe but is hard to find in the USA.
Jason
