Old 02-04-2006, 07:41 PM
hkxy hkxy is offline
hkxy is on a distinguished road
laser 1200-60W
New machine picture
ID:	14454   Click image for larger version
Old 02-04-2006, 10:09 PM
KTP KTP is offline
KTP is on a distinguished road
Why do they cool the HR mirror? That is weird...
Is the OC also cooled? Any idea of what gas mix is used in these lasers? I don't suppose they use Xenon do they? I have heard it extends tube life, but it costs as much as gold per ounce (or more?). Synrad uses like 7% or so!!!
Old 02-04-2006, 11:01 PM
It uses the mobile water cooling,Has the temperature the control,High or lowers in the scope which may controlDoes this the goal is the security and the time reason
Uses CO2 the gas,This and Sy is not same,Because its price is very low,Not need replacement gas,Only needed to purchase newly to be possible once more,Because he needs $260USD merely,But Sy 60W laser in here need $4000,Therefore he is the good choice,Is my DIY good choice
Old 02-04-2006, 11:08 PM
More pictures
ID:	14465   Click image for larger version
ID:	14466   Click image for larger version
ID:	14467   Click image for larger version
ID:	14469   Click image for larger version
Old 02-04-2006, 11:16 PM
2
ID:	14471   Click image for larger version
ID:	14472   Click image for larger version
ID:	14473   Click image for larger version
ID:	14475   Click image for larger version
Old 02-04-2006, 11:26 PM
3
ID:	14477   Click image for larger version
ID:	14478   Click image for larger version
ID:	14479   Click image for larger version
ID:	14481   Click image for larger version
Old 02-04-2006, 11:31 PM
4
ID:	14483   Click image for larger version
ID:	14484   Click image for larger version
ID:	14485   Click image for larger version
ID:	14487   Click image for larger version
Old 02-04-2006, 11:39 PM
5
This is uses the model airplane which my DIY laser machine does
ID:	14489   Click image for larger version
ID:	14490   Click image for larger version
Old 02-05-2006, 01:30 AM
KTP KTP is offline
Is possible to get new 60 watt tube for $260? Can give details please?
Old 02-05-2006, 01:31 AM
KTP KTP is offline
Also, Synrad 60 watt laser is not $4000. Try $7000+
Old 02-05-2006, 01:33 AM
KTP KTP is offline
You would get a better edge (less char) on those balsa pieces if you could use 20-50psi of clean dry shop air out of your CO2 lens nozzle.
Old 02-05-2006, 02:36 AM
CO2 Laser Technical Parameter
Length (mm):1200(250,400,450,500,600,700,800,1000,1400,1600,1800)
Mode(mm):Lower mode
Outer diameter(mm):Φ54±2(30,36,50,54,60,65)
Ignition voltage(KV):24(7,11,12,13,18,19,20,22,24,26,28,30)
Operating voltage(KV):16(6,9,10,11,12,13,15,16,17,18,20)
Operating current(mA):24(5,12,14,15,16,18,20,22,24,26,28,30)
Power Output(W):60(4,12,16,18,24,30,35,40,60,75,90W)
Power stablility:≤±5
Quality factor M2 1.2±0.2
Laser pattern TEM00 or TEM01
Light beam diameter lens
Design life 10,000 hours
He needs a power source:I purchase the price is $610USD
Possible choice:$260+$610=$870USD.
I have purchased,Produces the merchant to tell me it the life is 10,000 hours,6 months,Is not SY $7000,The cost is lowConforms to my requirement
He and SY is the different typeHas the difference the model
Thank you about balsa pieces and the less char suggestion
1st, input voltage: AC 220V±15%,
AC110V±15% (when ordering should explain specially);
2nd, maximum output voltage: DC 28KV (1250mm);
3rd, maximum output electric current: DC 20mA (1250mm);
4th, speed of response: <= 1mS.
5th, TTL level switch control: DC 5V;
6th, protects the switch: (1) lacks the water protection, (2) has flowed the limit protection, (3) overvoltage protection;
7th, the laser output adjustment (uses advanced PWM control technology):
(1) the 0-5V simulated signal, the control laser energy adjustment (coordinates software);
(2) TTL level switch control frequency output: DC 5V;
(3) by potentiometer manual regulation laser power source output current.
8th, use environment: Temperature (-10 ~ 40) ℃, humidity: <= 85%.
9th, external dimensions: 265×225×80 (long * width * is high) mm.
