Simple is good less trouble thay way
This is gonna be my baby, I know it's really simple, but i'm new in this.
What do you think?
- trim router mounted to quill shaft... options and router selection?
- Woodworking CNC Router,stone CNC router machine, metal mould CNC router
- Quote Awarded Newest CNC router machine from SINICNC-SIN-C3636 Mini cnc router
- Need Help!- with a Precix Table Router with Perske router
- Using a router for the 1st time. Need advice of cut speeds, router bits etc.
If you can use fully supported bearing rods then it will be best.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Rendered image
My machine mechanism same, but i see some people's cnc different.
Can you compare 2 type machines. What are the adwantages and disadvantages.
First Choice is x-y axis independent, z axis build on x axis
Example: compax's macine.
Second Choice is x axis build on y axis and z axis build on x axis
Example: Balsaman's machine.
Campax
Looks good. What package did you use for the design and then the rendering?
campaX,Originally posted by bunalmis
Your machine design is generally easier to build and more acurate. A great choice for the first time builder. The moving gantry style (like mine and Homecnc) is more complex but is smaller for the same cutting volume.
Nice design.
I wish it wouldn't crash.
I used SolidWorks for the desing and rendering, Its a really good program. I'm planning to build it next weekendOriginally posted by buckie555
Campax
