Old 08-01-2003, 08:48 PM
jlasner@co jlasner@co is offline
jlasner@co is on a distinguished road
Angry Hurco
Help!!!!! I purchased a used HERCO MILL and would like to us Bob Cad to send a usable code . The machine uses a conversational code programmed at the machine. I can receive ; but don't know how to generate or convert standard N.C. code to the hurco.hd3 code.
I use Bob Cad to generate N.C. programs for my TMC with great success.
Jerry
Old 08-01-2003, 11:52 PM
Mortek Mortek is offline
Mortek is on a distinguished road
Does the Hurco machine have an option to run ISO code? Might check into that as it will save you a lot of hassles. Most machines I know will accept ISO.
Old 08-04-2003, 07:25 AM
CHAD's Avatar
CHAD CHAD is offline
CHAD is on a distinguished road
You can not post an .hd3 file to your hurco. that is the conversational processor that is proprietary to them. you can however swithch the control over to the cnc side. if you don't have the industry standard option, the code is an older version of g-code. you have to do a few things a little different, like all your z moves in drilling canned cyles are incremental, and other things like that. It will take a little while to find all the differences. let me know if youy are haveing any trouble, and i will go back and see what i did to make the changes. What cam system are you using??? there is also a dxf option thta they have that works pretty slick for programming at the machine...
Old 10-03-2003, 10:59 AM
The One The One is offline
I hear they are working on the conversational post for Hurco. It is proprietary, so they are having to take a lot of time out to debug the conversion. If you can operate in g-codes for now, do it. I am also anxious to see how the new post will work.
I will let you know that the conversational posts normally take about sic weeks for them to finish. Simply because they can be so difficult to convert to from G-code.
The One
Old 01-30-2004, 06:45 AM
peter peter is offline
peter is on a distinguished road
hi jerry
on your machine you can change your editor from conversational
to nc which will allow you to use g-godes
then you can run your cad/cam through it
ultimax system use's its conversational .hd as its standard i dont know of any softwarehouse making a post for its conversational
format apart from hurco themselfs that was called pcmax it ran on your computer and give you the same screens as the ultimax twin screen and allowed offline programming,but to make the machine more universal they incorparated iso programming allowing for 3d shapes which even its 3d option cannot produce
to be made using iso
post format is very simple to do
so there should be no reason why you can not talk to the ultimax controller
hope this helps
best regards
peter
new here, need help with hurco SteveD Machine Problems, Solutions , Wireless DNC, serial port 8 06-02-2008 10:47 PM
Mastercam with *old* Hurco CNC Miller ReValveiT Mastercam 25 05-19-2006 08:01 AM
Hurco service manuals required Graham S CNC Plasma and Waterjet Machines 1 12-11-2005 09:15 PM
Problem Loading Master on HURCO KM-1 JREEN2 General CNC (Mill and Lathe) Control Software (NC) 0 12-05-2004 06:12 PM
