Old 07-08-2005, 02:41 PM
FLUTE HEAD's Avatar
FLUTE HEAD FLUTE HEAD is offline
FLUTE HEAD is on a distinguished road
x-axis alignment
specs: harbor freight round column benchtop mill. What would be a good way to make sure that the x-axis ballscrew is running parallel and concentric to the x-axis ways? I could run a test indicator along the face of the ball nut housing to get the housing parallel to the x-axis, but what about alignment? I'm not so sure that the holes drilled for the original x nut mount were aligned correctly. If they were then I could use coutersunk socket head screws that would sort of "self align" to the bottom of the x nut mounting holes, being that they were drilled and have a taper from the drill bit. What approach do others use for this process?
Old 07-10-2005, 01:21 AM
Jay Kyle Jay Kyle is offline
Jay Kyle is on a distinguished road
Have a look at www.industrialhobbies.com , they have a series of steps that show setting up an x-axis on their mills.
Jay
Old 07-10-2005, 10:05 AM
FLUTE HEAD's Avatar
Thanks, had a brief look at the site. nice site. I'll keep lookin through.
Laser spindle alignment? cgallery DIY-CNC Router Table Machines 4 09-25-2006 01:15 PM
Mini Mill alignment tpicker1 Benchtop Machines 5 05-12-2004 05:36 PM
Alignment, backlash, limit switches etc CNC Brute DIY-CNC Router Table Machines 8 01-17-2004 09:05 PM
Alignment and squareness issues boxwood DIY-CNC Router Table Machines 2 08-23-2003 09:20 PM
