Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > General Electronics Discussion
General Electronics Discussion Discuss basic electronics, power supplies and anything else electronic related here.
Old 06-01-2005, 01:39 AM
Nono's Avatar
Nono Nono is offline
Nono is on a distinguished road
110 single phase to 220 single phase.
I am not sure how to ask but here I go...... I need to wire a 220v motor up and am not sure how to do it, the service into my house is 110v. A dryer uses 220 I thought (the plug that I am using) but that is two 110 legs a neutral and a ground not true 220v or is it?.The motor that I have only has three wires so would I wire the black and the red to the black, neutral to neutral and ground to ground. Any constructive information would be helpfull.
Old 06-01-2005, 05:26 AM
Karl_T's Avatar
Karl_T Karl_T is offline
Karl_T is on a distinguished road
The power to your house is 220 volt off a "center tapped transformer". That is, one hot leg is 110 volt to nuetral in the center. The other hot leg is 110 volt to nuetral in the center. And there's 220 volt between the two hot legs.
Going by colors don't always work, but in general, one hot wire is normaly black, the other hot is red, the nuetral is white, and ground is green. A cheap multimeter to check voltages would help you out.
Karl
Old 06-01-2005, 08:56 AM
cp8071 cp8071 is offline
cp8071 is on a distinguished road
Your motor is 220 single phase, so it only uses the two hots and the ground, NOT a neutral. Most motors can be rewired for 110 but will draw twice the current which can be too much for residential wiring, but if it's low horsepower then it might be easier in the end to rewire it rather than plugging into the dryer each time.
CP
Old 06-01-2005, 09:38 AM
mxtras's Avatar
mxtras mxtras is offline
The Village Idiot
To add to the confusion - many times in residential and some commercial service, the neutral and the ground are the same potential.
To get 220, use the two 110 legs (which are likely around 117 each) and ground, as cp8071 said.
Scott
Old 06-01-2005, 09:40 AM
Flyinfool Flyinfool is offline
Flyinfool is on a distinguished road
If your motor has 3 wires comming out and one of them is not green, it is possible that you have a 3 phase motor.
often times the ground connection is not a wire, but instead a screw terminal.
There should be a name plate on the motor or machine somewhere.
On that nameplate there should a listing for volts, (110 or 220), frequency or Hz (50 or 60) and Phase or Ph (1 or 3), Horsepower or HP.
Let us know what that nameplate says or post a picture of it if you can.
Jeff
If it aint broke, fix it till it is.
Old 06-01-2005, 12:06 PM
Nono's Avatar
So am I to understand that the three wires that come off this switch are two hots and a ground. the wires are black white and green.. There isn't any wiring diagram for it. I can put in another outlet for it. How would I wire the outlet? I am thinking that an older 3 prong 220v dryer plug would sufice...
the motor has five wires where it wires up to the switch and the switch itself has only three wires
Old 06-01-2005, 12:14 PM
mxtras's Avatar
The Village Idiot
Are you sure this is not a three phase motor?
Scott
Old 06-01-2005, 12:16 PM
...as others have hinted...we need more info.
What kind of motor is this? What is it's purpose (original and also how you intend to use)? How do you know it's 220 if there is no info on it?
If this is a euro hairdryer/blender/toothbrush then that's one thing ... if it's an industrial motor that's 20 horsepower then the answer will be completely differrent.
So give up the info/pictures if you want the right answer.
CP
Old 06-01-2005, 12:22 PM
mxtras's Avatar
The Village Idiot
Maybe this will help????
Scott
Old 06-01-2005, 12:24 PM
Nono's Avatar
Sorry for the wait But this is a an industrial hobbies mill and it is single phase
Old 06-01-2005, 12:26 PM
Nono's Avatar
another
Name:	Motor cover.jpg‎
Old 06-01-2005, 12:49 PM
Excellent!!!
Yes, It's a single phase 220V motor (hard to read, looks like "22nV"). You'll notice on the wiring diagram that they label the incoming power as L1 and L3 ... those are your two hots (however they are colored). No neutral is needed, only a ground.
Now you just have to figure out how you're going to plug it into anything. The dryer plug is a good place to start, but if you create an "extension/adapter cord" you need to be very careful since that smaller gauge wire will fry before it trips that 30-50Amp breaker designed for the dryer. Adding a new 15-20 Amp 220V circuit would be better. You'll also notice that it's hard to find a standard plug for this type circuit since it's outdated and only used for specific (high-current) things now.
edit: Forgot to add, the diagram on the motor shows the connections for forward and reverse rotation ... if you look at that diagram and the other you'll see how the reversing switch works by changing the starting circuit between the two legs.
CP
VFD for a single Phase motor!! Yepez Servo Motors and Drives 4 08-10-2009 07:53 PM
Single to Three Phase Help, Please elalto General Metal Working Machines 20 01-04-2006 06:01 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 12:25 PM
2KVA 220 to 110 transformer. Can it be used with 110 volt primary? And gantry pic Bloy2004 General Electronics Discussion 9 06-29-2004 09:28 AM
Single phase Fadal nervis1 Fadal 9 12-24-2003 11:32 AM
