Old 05-23-2005, 06:38 PM
Jay Kyle Jay Kyle is offline
Jay Kyle is on a distinguished road
Square Column Mill/Drill Conversion
Just bought a Square column mill/drill that is almost converted to CNC, however I have a couple of questions about design. Here's what the mill looks like new.
1. Should the z-axis control the entire vertical head movement, or just the quill. Seems like it would be nice to have the complete range of the head under NC control. This means tossing out the head raise/lower motor and put in a large stepper (due to the weight involved), then just use the quill for any sort of quick drilling.
2. Is it better to direct drive the stepper motors or use a step-down belt system for the axis (assuming ballscrews?)
The goal is to turn this into a working 4 axis machine!
JK
Old 05-23-2005, 10:23 PM
Nono's Avatar
Nono Nono is offline
Nono is on a distinguished road
I just bought one very similar to that from industrial Hobbies.. Very Cool I am planning on a 1200 oz for the z axis for the full head and leave the quill for manual tool offsets and quick drilling. I am planning on cutting lots of stainless and titanium with this so I will step down the x y with pulleys using 800oz steppers and ball screws from http://www.homeshopcnc.com..
Old 05-24-2005, 12:58 PM
Hey, thanks for pointing out industrialhobbies.com, there's lots of good material on that site for what we're doing.
Sounds like some pretty hefty steppers, do you really need them that strong? What does that give you?
Old 05-24-2005, 01:27 PM
ChrisJ ChrisJ is offline
ChrisJ is on a distinguished road
Don't forget the tighter you make the gibs the more power/torque you will need to move the axis's, and you may need fairly tight gibs for accurate cutting.
I bought an IH mill and their 3-axis conversion kit and I am in the process of building it back up. Very nice kit and a lot of thought went into the design. I know he is not advertising for sale individual components anymore but I would see if he would sell you at least his optical limits. You can't beat the design. Accurate and coolant proof.
If you are looking for speed you may want to consider servo motors instead of steppers.
Chris
Old 05-24-2005, 10:48 PM
Nono's Avatar
I want a lot of power but that is just me.. If it was set up with the right pully system/Ratio you could put 200 or 300 oz motors but I look at it as why make your machine slow in the rapid traverse.. the table isn't that big and I will mostly be using hss/cobolt cutters anyway. I have decided on using steppers instead of servos because the encoders are built into them. Finding motors is easy,, Ebaythe word stepper and then servo and you will see what I mean.
Old 05-25-2005, 11:42 AM
Ok now I've got the bug to go to larger steppers and direct drive them. I see that cncmasters uses 1200 oz direct drive steppers for all axis. I wonder how it's working for them.
When I start looking at the torque curves for the NEMA 34 steppers, it seems that when comparing a ~600oz stepped down 2:1 to a 1200 oz direct drive, there's barely any difference in torque at 1000 rpm. Those higher power motors really loose their torque fast as RPM increases compared to the lower power motors in the same frame design.
JK
Old 06-29-2005, 12:50 AM
Ballscrew bearings
Hello all,
I'm still working away at it!, getting techno-isel 25mm ballscrews coming in for it. The ballnuts fit into a nice square mount and the nuts are also pre-load adjustable without having to purchase a 2nd nut.
I'm getting a gas spring to counterbalance the head, 1300 oz steppers for x,y,z axis and am designing direct drive mounts for them.
I've run into a design conundrum however, I'll be using 2 angular contact bearings on the fixed (motor) end of each ballscrew. According to popular design the inner and outer races of the bearings are tightened together separately. This makes for rather large mounts... I'm wondering if I can skip this and use just the ballscrew bearing nut to draw the 2 bearings together sandwiching the bearing housing.
.. any thoughts?
Jay
Name:	x-axis ballscrew fixed assy.jpg‎
Old 07-05-2005, 02:13 AM
Ok question solved from the last post, I'm going with the traditional bearing mount style. For those who are interested I'm attaching the drawings I created to build the X-Axis direct drive mount for the new ballscrew and stepper. I created these drawings in Alibre, a nice cad package but I used about 1.4 GB of virtual memory on a machine that has only 512 mb of ram, so I was in the swap file a lot. Also Alibre really needs a good video card as I couldn't get it to draw a complete helical ball threads without visual distortion of the threads (using a NVidia MX 400 video card).
Jay
Name:	X-Axis Assembly.png‎
ID:	8540   Click image for larger version
Name:	X-Axis BallScrew.png‎
ID:	8541   Click image for larger version
Name:	X-Axis Fixed Bearing Mount.png‎
ID:	8542   Click image for larger version
Name:	X-Axis Free Bearing Mount.png‎
Name:	X-Axis Fixed Bearing Mount2.png‎
ID:	8544   Click image for larger version
Name:	X-Axis Fixed Bearing Mount Cover.png‎
ID:	8545   Click image for larger version
Name:	Bearing Sleeve.png‎
Old 08-11-2005, 10:45 AM
ngr1 ngr1 is offline
ngr1 is on a distinguished road
Hi Jay... Any updates?
Old 08-11-2005, 01:15 PM
There is, but I'v been on vacation and out of town on work so not as much as I'd like. However all parts have finally arrived as of earlier in the week - that includes the new steppers, ballscrews and nuts, bearings, seals, etc, and gas spring for counterbalance.
The ballscrews are at my friends machine shop for him to turn the ends. When I get home this weekend I'll stop by to see how he's doing.
Jay
Old 08-20-2005, 12:49 PM
MikeAber MikeAber is offline
MikeAber is on a distinguished road
This bearing would simplify your design and it is not necessary to put the bearing at the motor end, it could be at the other end of the ball screw.
http://VXB.com stocks these.
http://www.vxb.com/page/bearings/PRO...ONTACT/Kit6933
1 Ball Bearing 5204 ZZ 20x47x20.6 Chrome Steel - Metal Shields - Double Row Angular ContactCode:Kit6933
Price: $9.95
Old 08-20-2005, 02:05 PM
DieGuy's Avatar
DieGuy DieGuy is offline
DieGuy is on a distinguished road
Another economical way to counter balnace the Z is to use a pulley and cable system to a counterweight on the back of the machine. Then the loading is adjustable by just adding weight to the counterbalance. I suspect that a much smaller motor could be used to drive the head in that case as you have gravity to help you.
As a quick second though a couple of recycled hydralic cylinders could be used with a counter weight as well.
Mill/Drill conversion coming right up! balsaman Vertical Mill, Lathe Project Log 214 04-29-2009 09:04 PM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 11:24 AM
square column mill conversion triberman Benchtop Machines 23 07-26-2005 09:00 PM
Harbor Freight Mill/Drill Conversion Log Halfnutz Vertical Mill, Lathe Project Log 31 04-13-2005 11:56 PM
Biggest Square Column Bench Mill in the US. IndHobby Product Announcements & Manufacturer News 0 10-31-2004 03:33 PM
