Old 05-17-2005, 01:37 PM
miljnor's Avatar
miljnor miljnor is offline
S.N.A.F.U.
diy Mini lathe test bed
well here is the "throw it together as fast as I can" mini lathe..
Had to do something to fill all those voids in my schedual.
its all low buck.. a test be for all the cam systems out there So far Mach3 is the winner.
first picture is of the somewhat finsihed controler box.
second is Enco lathe. just a slightly higher quality HF lathe
third is the x limit switch
forth is the z limit switch
fifth is a slightly blurry pic of the encoder for spindle timing. (would make another but am at work.)
Name:	tn_lathe control bx.JPG‎
ID:	7678   Click image for larger version
ID:	7679   Click image for larger version
Name:	tn_x limit switch.JPG‎
ID:	7680   Click image for larger version
Name:	tn_z limit switch.JPG‎
Name:	tn_spindle encoder.JPG‎
thanks
Michael T.
Adapt, Improvise -- Overcome!
k.r.t.
Old 05-17-2005, 02:08 PM
JavaDog's Avatar
JavaDog JavaDog is offline
JavaDog is on a distinguished road
Nice looking little set-up you have there!
What do those lathes run, cost wise?
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 05-17-2005, 02:14 PM
Chris D's Avatar
Chris D Chris D is offline
Chris D is on a distinguished road
Nice coversion so far!
What size steppers are those (in. Oz.)? and what ball screws are you using?
Java Dog, the harbor freight version run around $400.
Chris
Old 05-17-2005, 02:38 PM
DieGuy's Avatar
DieGuy DieGuy is offline
DieGuy is on a distinguished road
I see you have the Ford fine adjustment tool out!
Old 05-17-2005, 08:23 PM
miljnor's Avatar
S.N.A.F.U.
ya that tool holds about .0002" tolerance all day long
the stepper motors are Hobbycnc (as well as the kit) 200oz/in. which I originaly thought were quite punny, but I soft crashed last night (took a .100 cut radius ) and tripped getting to the e-stop and the motors were making a hell of a raquet. But after re-zeroing the machine. Turns out the only thing I overloaded was the underpowered spindle motor. Didn't even miss a step!
The lathes are the same prices as HF but IMO are a little better quality, and you know the yellow goes better with hair.
I paid 399.00 +sh
The Motor mounts I was too busy/lazy to make so I bought them from http://cnc.wc101.com/ They work great! and saved me Lots of time. Ask Paul I think he's got them on his lathe as well
thanks
Michael T.
k.r.t.
Old 05-18-2005, 07:35 AM
RotarySMP's Avatar
RotarySMP RotarySMP is online now
I think the Mini Lathes with 200 OzIn make a very forgiving CNC trainer, The only thing way to damage the machine is running into the running chuck, otherwise either the spindle stalls or the steppers stall. I have 2A fuses in mine (240V here) and the fuses blow just as the spindle stalls. Never had a problems with the spindle mosfets.
I only did home switches as +X stalls on the bearing mount, - X stalls on the back of the enclosure. +Z stalls on either the leadscrew bearing block or the tailstock, and -Z could be dangerous, but is not a defined position as it depends on whether collets, faceplate, three Jaw or four is in use at the time.
Did you copy the X axis home/end switch from my machine?
http://www.wrathall.com/Interests/CN...e_Switches.htm
I am not happy with it here. Gets completely covered in swarf. I'd love to find a better location for this, or come up with effective shielding.
Regards,
Mark
www.wrathall.com
Old 05-18-2005, 08:51 AM
JFettig JFettig is offline
I ended up putting my X+ home switch on the motor mount and my Z switch on the back side way at the end, couldng really get a good picture of it way back there but I tried
miljnor: if you want a little more reliability, take the handwheel and gears out of the carrage, or at least protect it from chips. I had some large chips get into mine and it would stall if it couldnt make it over them.
Jon
ID:	7694   Click image for larger version
ID:	7695   Click image for larger version
Old 05-18-2005, 11:15 AM
miljnor's Avatar
S.N.A.F.U.
good point on the hand wheel I've only used it twice and both times ended up cutting my hand because of the closeness of the motor mount. (its always something)
http://www.wrathall.com/Interests/C...me_Switches.htm
No I didn't copy you but I might as well. thats exactly where I thought would would be easyist. Great minds think alike!
The swarf issue will be my next tackle after cleaning up the controler box. (its goto look good, even if it dosn't run, its goto look good)
thanks
Michael T.
k.r.t.
Old 05-18-2005, 04:28 PM
RotarySMP's Avatar
Jon, I guess you must be just making small stuff on your lathe, as you must have very limited X travel. I really should have a bigger lathe. The job I just finished was 100mm diameter pulley. Unfortunately I don't have any more space, so the poor little 7x just has to make do.
Mike, I guess none of us has come up with a really good solution for the home switches. If great minds think alike, maybe we mediocre minds do also
I have been thinking about making up a set of sheet metal sliding swarf guards like the real CNC's have, but the relationship between min space between X slide and motor bearing mount, and travel would mean I'd need 5 or 6 panels.
http://www.wrathall.com/Images/107_0708.jpg
My cross slide is longer, and the travel increase by about an inch more than stock.
I am just in the process of retrofitting to ball screws, and have designed in a swarf guard for Z.
We I get all the bits made, the whole machine needs a going over to fix a bunch of stupid things I did in cable routing witch now make maintenance a real PITA.
The enclosure made a huge difference to the machine.
Regards,
Mark
www.wrathall.com
Old 05-18-2005, 04:44 PM
Mark, yes, mostly I have been making stuff less than 3" but I could cut a part from center out to 5.2" in diameter with my setup. I have the tooling plate that I made that extends back over the mount and I offset my tool post back.
My next thing i want to do is convert over to ballscrews or at least the Z-axis, I have a ballscrew all made up but havent made the skirt for it yet, I have seen some ballscrews on ebay that appear to be small enough to work in the cross slide.
The swarf gards your considering, what parts would they cover? before I put the z-axis screw in, I will make a cover that bolts on where the rack bolted on, I might make some way wipers as those are not looking the greatest anymore.
Jon
Old 05-18-2005, 05:48 PM
Bloy2004's Avatar
Bloy2004 Bloy2004 is offline
Fumbling Machinist
Bloy2004 is on a distinguished road
Is this partly of what you want to cover ? I left the hand crank in for easy traversing during setup and whatnot. Maybe I won't need it if I can accomplish everything with CNC.....
Name:	gear cover for mini lathe.jpg‎
Old 05-19-2005, 12:15 AM
miljnor's Avatar
S.N.A.F.U.
The plus side for you making your own way covers is you can do them right. (which means they will actually keep chips out of the screw area) there isnt a commercial machine on the market that does a good job of this.. Sure they work when you get them for a couple months up to a couple years but after that they suck.. and replacement covers never seam to do the trick. So what would be prohibitively expensive for the factory (hand making and fitting) you can do fairly cheaply..
Of course now you have to come up with something better..
I of course go for the practical route knowing the chips will get everywhere i opt for the simple rubber covers maybe a bellows or something to prevent direct chip assault! And lots of cleaning.
thanks
Michael T.
k.r.t.
Mini Lathe Tooling plate JFettig Mini Lathe 20 08-10-2005 12:14 AM
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 03:07 AM
mini lathe marto74 Haas Lathes 6 03-04-2005 07:01 AM
Mini lathe conversion kdoney General Metal Working Machines 1 08-26-2004 11:21 PM
Mini Lathe - Homier JFettig Mini Lathe 11 02-20-2004 03:58 PM
