Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 12-03-2009, 03:59 PM
Mini Beast's Avatar
Mini Beast Mini Beast is offline
Mini Beast is on a distinguished road
Flood Coolant Enclosure
Well, I'm finally getting around to giving Mini Beast his next major upgrade. Cheap and functional are the design goals. This thread will act as a build log, in addition to me asking some questions and advice of our gracious cnc zone members who know way more than me.
I think I'm going to use wood and a base similar to this guy's. Also, I was thinking of using this for the coolant pump and reservoir. I'm still unsure of exactly how I'm going to filter the returning fluid. Also, can someone suggest a good coolant to use? There seems to be so much to choose from.
DISCLAIMER: I'm a noob :)
Old 12-04-2009, 07:30 AM
coolantman's Avatar
coolantman coolantman is offline
coolantman is on a distinguished road
EnviroServe Chemcals has some great coolants.
www.enviroservechemicals.com
Old 12-10-2009, 08:03 PM
SpeedsCustom's Avatar
SpeedsCustom SpeedsCustom is offline
SpeedsCustom is on a distinguished road
I'm going to post some pics of my enclosure for you, I have one of the best designed filtration systems...I think. I never get chips in the tank.
Enjoy
Old 12-11-2009, 03:21 PM
Mini Beast's Avatar
Thanks for sharing, Speeds. I like your design. It's really simple and looks like it would be easy to clean. What type of coolant do you use?
Old 12-11-2009, 06:28 PM
mactec54 mactec54 is online now
Gold Member
mactec54 is on a distinguished road
Mini Beast
If you are in your home you want to use GreenCut
http://www.greencut.com/
Mactec54
Old 12-11-2009, 11:22 PM
Mini beast- I have to be honest, I don't know. I was given a 2 liter bottle of this blue coolant from my GF's father (Machinist...duh), it was given to me about maybe, two years ago? Still have more than half the bottle, love the way smells; I must be a freak lol but it's fantastic, doesn't get all gross and stinky, just has a nice machine coolant smell.
I'll try and find out tomorrow. If your interested in how my coolant system works, just ask, but it's pretty simple to see.
-Jason
Old 12-12-2009, 11:37 AM
BobWarfield's Avatar
BobWarfield BobWarfield is offline
BobWarfield is on a distinguished road
Jason, would love to know more. For example, the picture of the coolant chute. At first I thought you had done that to make it easy to clean out the chips, but now I'm wondering if it isn't like a gold sluicer to separate the chips?
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 12-12-2009, 12:12 PM
Bob- Most of the catching is done in the actual enclosure, inside is a hole for the coolant to drop into that angled beam. In the enclosure is one of the humidifier pads with some stock on top to keep it compressed; this catches the bulk of the chips. The key is not to have gravity and coolant force chips through a filter, so instead, the coolant and whatever chips get through they simply slide gently down the beam. The encounter the first filter and finally the last filter where simply coolant just falls out into the oil drain. The oil drain itself has a mesh screen that does catch one or two chips that gets through, but nothing in the tank. Clean up is easy, just need to stick the vacuum cleaner down along side the beam and get those chips.
-Jason
Old 12-16-2009, 12:12 PM
Mini Beast's Avatar
Originally Posted by mactec54 View Post
Mini Beast
Thanks for the suggestion, this stuff sounds pretty good. Lots of good information on their website, but it astounds me they don't leave any clue about how to purchase the stuff. Is it possible to order this stuff?
Old 12-16-2009, 03:29 PM
Gold Member
Mini Beast
Pm me I have it in stock
Mactec54
  #11   Ban this user!
Old 12-18-2009, 09:27 AM
Mini Beast's Avatar
Here is the progress so far. This isn't near as fancy as some other enclosures I've seen, but I'm staying with my goals of cheap and functional. So far, it looks like my total cost will end up somewhere in the range of $200-300
1. Heavy wooden frame to be the stand
2. Fiberglass a 2x10 to make it waterproof. This will be the surface I mount the mill on and luckily the only fiberglass work I plan on doing this project. (That stuff is nasty!)
3. A concrete mixing tub that fits perfectly into the frame (yes, I planned it that way ). I cut holes in it for the 2x10 to pass through and for a shower drain to be installed.
4. Lag screws secure the 2x10 and some silicone to keep the tub water tight.
5. Mini Beast fits in there like a glove!
ID:	95444   Click image for larger version
ID:	95445   Click image for larger version
ID:	95446   Click image for larger version
  #12   Ban this user!
Old 12-18-2009, 09:34 AM
Absolutely fantastic idea; however...how is the base supported in that tub? Is it secured tightly or what?
When I first started my enclosure a few years ago, this is what I had. I had the same exact tub mixer on a table, but my drain leaked etc.
-Jason
Flood coolant evaporation rezcar General Metalwork Discussion 4 09-26-2009 09:03 AM
Flood coolant for a bandsaw tlyee63 General Metal Working Machines 5 08-22-2009 05:23 PM
X2 Flood Enclosure mrcodewiz Benchtop Machines 9 12-03-2008 10:28 AM
My new TAIG and enclosure...also flood cooling ?'s VTX Taig Mills & Lathes 34 10-16-2007 11:22 AM
Flood coolant on steroids Scott_bob Machine Problems, Solutions , Wireless DNC, serial port 7 04-30-2007 01:07 PM
Powered by vBulletin® Version 3.8.5
