Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #73
Old 03-23-2009, 07:48 PM
Zoidberg Zoidberg is offline
Zoidberg is on a distinguished road
Made a little animation of the 81:1 gearing!
Old 03-23-2009, 09:17 PM
I did just figure out how to draw the lobes correctly
With a little bit more drawing i realised that was wrong! The correct way (i hope) is in the PDF. It looks good anyway
Edit: It should be: Y/4 = Eccentricity
Old 03-24-2009, 12:59 PM
Yet another variant :P A single stage cycloidal traction drive with -59:1 ratio.
I used an oldham style output.
A little video.
I REALLY need to get my mill working soon
ID:	78294   Click image for larger version
  #76   Ban this user!
Old 03-24-2009, 02:19 PM
NEATman NEATman is offline
NEATman is on a distinguished road
Zoidberg-
Ingenious use of an oldham coupling! Very cool.
You could have the output stage of the oldham clamp directly to the shaft you are driving, and eliminate the need for a traditional coupling. It would reduce the length, and remove the bearing on the output shaft.
Keith
Old 03-24-2009, 02:22 PM
Yeah that would be cool! But then you probably would need 2 bearings on the input axle to support the radial load!
  #78   Ban this user!
Old 03-24-2009, 02:29 PM
If you kept the bearing inside the output cup there wouldn't be any radial load on the output clamp. I suppose that that it could cause angular alignment problems when it comes to mounting it, but to be real clever, you could have a slightly spherical section on the end of the eccentric shaft that would fit into the ID of the bearing mounted in the output cup that would minimize slight angular misalignment.
Old 03-24-2009, 03:26 PM
What about something like this? Then it's balanced for higher speeds also
  #80   Ban this user!
Old 03-24-2009, 03:35 PM
I like that as well. Counteracting forces almost cancel out. How about a adjustable paralell type wedge that would preload one up and the other down - against each other, instead of against the cone angles on the setscrew? That way, it would ensure that there was equal and opposite forces acting on the contact points.
Alternately, you could hollow out the input shaft on the left and put a setscrew in from that side as well and balance the loads at assembly.
  #81   Ban this user!
Old 04-05-2009, 06:08 AM
aystarik aystarik is offline
aystarik is on a distinguished road
Here is some math and CNC info about gear profile... In short, it can't be described by two arcs
http://gears.ru/transmis/zaprogramata/2.139.pdf
  #82   Ban this user!
Old 04-05-2009, 06:17 AM
Some more oldham coupling -- with rollers.
http://www.spinea.sk/page.php?id=1
Old 04-06-2009, 08:36 AM
Ah, cool! I have to write a rhinoscript or something
  #84   Ban this user!
Old 04-07-2009, 10:42 PM
Mike Everman Mike Everman is offline
Mike Everman is on a distinguished road
Hey Zoid, I like that last reducer. Only comment is the (radial force) balls need separate setscrews, or better still, no thread in the main shaft, and a nifty way for one ball to push against the other, so radial load equalizes.
BTW, I've got a bucket of Santotrac grease when you get down to it. It was a minimum order thing. The stuff is like ear wax, if you've never seen it. ha
Mike Visit my projects blog at: http://mikeeverman.posterous.com/
http://www.bell-evermannews.com/ http://twitter.com/mikeeverman
Rotary Table Backlash fc911c General Metal Working Machines 4 04-18-2010 04:11 AM
Anti-backlash rotary joint existance TomB Linear and Rotary Motion 8 07-23-2009 12:01 PM
rotary table bulletfab Haas Mills 4 12-16-2007 02:48 PM
Rotary table Piobaire HURCO 0 08-22-2007 07:30 AM
Typical Backlash on a new Yuasa 8" Rotary Table Roy Norris General Metalwork Discussion 5 08-10-2005 04:33 AM
Powered by vBulletin® Version 3.8.5
