Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > General Metalwork Discussion
General Metalwork Discussion Discuss everything relating to metal work.
  #37   Ban this user!
Old 01-20-2007, 06:11 AM
Barry_ward's Avatar
Barry_ward Barry_ward is offline
Barry_ward is on a distinguished road
Spindle Speeder
Bob,
Got any leads on HS spindle bearings and construction that I could use on the belt drive speeder?
I'd never seen "speeders" until you mentioned them. Cool, but expensive.
I'll be in China this coming week and will shop the machining district for a speeder. If I don't find anything I'll eventually build that belt drive....
Barry
my projects:
http://www.barryfish.com
  #38   Ban this user!
Old 01-21-2007, 06:18 AM
bill south's Avatar
bill south bill south is offline
bill south is on a distinguished road
Bob;
Where did you source the springs you added to the system and what are the specs. After a couple of weeks us, my system is starting to stick on the drawbar. I think springs would be the easiest fix.
Thx.
Bill from Spartanburg
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  #39   Ban this user!
Old 01-21-2007, 10:41 AM
BobWarfield's Avatar
BobWarfield BobWarfield is offline
BobWarfield is on a distinguished road
Bill, I just grabbed a couple of springs at the hardware store. They were big enough to fit the uprights and probably 2-3" long. The exact spec is not so critical because I use movable collars to adjust them for best performance.
Best,
BW
  #40   Ban this user!
Old 01-24-2007, 07:41 PM
wildcat wildcat is offline
wildcat is on a distinguished road
Just curious - for those that have installed these on gear head mills - are you shifting the gear head to the lowest gear before activating the power drawbar? I wonder since the spindle rotates so easily when in the highest gear. Doesn't the power drawbar end up spinning the spindle a lot?
  #41   Ban this user!
Old 01-24-2007, 09:02 PM
locoind locoind is offline
locoind is on a distinguished road
I'm not familiar with a lot of different types of mills, but we have 3 bridgeports, and 1 clausing where I work. We have kurt draw bars on all of them. They're pretty simple in action, but they utilize a piece of extruded aluminum that could be duplicated using pins. The basic idea is when the handle is pushed to the left, the butterfly is drawn down, and the correct side of the paddle is pushed in at the same time to unscrew/screw in. And the opposite for the other way. I can get some pics, and basci measurements, as long as no one has any worries about copyrighted.(even though reproducing the exact extrusion would be very hard.) Someone will have to guide me through the pic posting part.
  #42   Ban this user!
Old 01-24-2007, 09:56 PM
I've never yet had this problem, regardless of what gear I'm in. I do know of some folks who have made up spindle wrenches to hold the spindle and get things tight.
I also came across a swell idea on the HSM board. This fellow made a little spacer that sits under the drawbar and keeps it centered. Great idea:
I do find my drawbar is sometimes not quite centered and this would be very helpful. I've yet to make one up though.
Best,
BW
  #43   Ban this user!
Old 01-24-2007, 11:32 PM
Bob - The spacer is an absolutely fantastic find! I was planning on turning down the end of the drawbar but this will work a lot better. Got my weekend project now Thanks!
I have made some wrenches and they are a great improvement over having to shift gears. Maybe I'll start the power drawbar this weekend as well... So many projects
  #44   Ban this user!
Old 01-25-2007, 09:23 AM
bill south's Avatar
Gents;
The drawbar on my lathemaster benchtop works great regardless of the headgear. The only problem I have is the socket missing the drawbar when it is not quite centered. I'm going to try the bushing idea and correct this (hopebully).
Question for Bob, what material was used for your model. I was kinda thinking aluminum since it would be easy to work with and would wear before the drawbar or spindle. I'd rather replace the bushing!!!
Thanks in advance.
Bill from Spartanburg.
billyjack
  #45   Ban this user!
Old 01-25-2007, 10:15 AM
Originally Posted by bill south View Post
Gents;
Thanks in advance.
Bill, the picture is of someone else's spacer. I haven't gotten round to it yet. When I do, I plan to use 12L14 steel. It's pretty soft and I doubt there will be that much wear on the drawbar. It is super easy to machine. I guess I'd better get that spacer made tonight!
Best,
BW
  #46   Ban this user!
Old 01-31-2007, 06:58 AM
digits digits is offline
digits is on a distinguished road
Best,
BW
Hi - I bought myself a set of those super-simple drawbar plans, but what I can't understand is whether or not you still need to use a (manual) spindle lock during tool changes. From what you've written above, it sounds like the impact wrench is undoing/retightening the drawbar even though the spindle is free to spin? Is the drag from the spindle motor and the inertia of the spindle enough to hold it steady?
  #47   Ban this user!
Old 01-31-2007, 08:38 AM
Yes, it works fine without a spindle lock.
Best,
BW
  #48   Ban this user!
Old 01-31-2007, 12:17 PM
Best,
BW
Cheers - thanks for the info
Powered by vBulletin® Version 3.8.6
