A lot of people use Mach2 (and now Mach3) with 750Mhz PC's w/ 256MB RAM. With a clean install of Windows, and nothing else, that should be all you need. Although if you need the 45Khz step rate, then yes, you will need the system you mentioned.Originally Posted by wmgeorge
DeskCNC will supposedly run on just about everything.
