Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Shopsabre
Shopsabre Discuss shopsabre machines here.
Old 12-30-2008, 02:56 PM
MarkWink is on a distinguished road
Shopsabre Motor Coupler?
The spider on the Y axis of my 4896 is worn (low time - couple hundred hours).
Has anyone tried a Helical style of coupling? any recommendations?
Old 01-10-2009, 03:12 PM
FYI - Spider had been modified (5/8" hole thru the center) to accommodate a design "feature" lead screw shaft too long or motor mount too short.
That much matrl. missing caused the spider to deform and wear.
New shopsabre BensMillwork Shopsabre 27 01-17-2009 12:35 PM
Problem- Broken Motor to BallScrew coupler IMK1230 Syil Products 11 01-05-2009 09:29 AM
Shopsabre ATC Probblem dsgnkrft Shopsabre 3 11-05-2008 10:03 PM
Coupler motor question MagTDK DIY-CNC Router Table Machines 7 08-07-2006 06:37 PM
Making a coupler between motor and lead screw nikolatesla20 Mechanical Calculations/Engineering Design 8 07-30-2005 02:05 PM
