I bought mine direct from wincnc which is the operating system guys. If you need help and support, you may be better off getting one from shopsabre. I wouldn't go without it.
All:
I recently acquired a used 4896 with ATC and have finally set it up for use. I love the tool measure option, but I feel like zeroing the z-height is still a little fiddly as it depends on my setting the bit at the right height manually. My machine did not come with the touch pad and I was thinking of getting one. What do folks do for accurate z height set up?
Anil
