Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Selling shoptask
    May 2009
    Selling shoptask
    Has anyone else contacted John Taylor to verify if he is seeking to sell shoptask. I can't locate the thread that I saw today.
    Banned
    Nov 2007
    I guess he didn't want anyone to know he is going out of business.
    Aug 2006
    there maybe a god after all.
    Banned
    Nov 2007
    I think he will be roasting where he is going. Norvil I think we finally got justice. He could have just made things right and he wouldn't be where he is right now.
    May 2009
    I spoke with JT yesterday
    I spoke with John Taylor yesterday after I saw a post here that said he was selling the company. He said that he wasn't selling.
    As to the quality problems which two of you keep referring too, that would explain his move to have the Patriot manufactured in an ISO 9001 certified plant. He apparently wasn't safisfied with quality and moved to upgrade his product quality.
    I just spoke with Grizzly manufactuing about a lathe and mill which they are advertising. Available in July........maybe. And they aren't manufactued in an ISO 9001 certified plant.
    I have used several Jet lathes and each of them had to be disassembled, cleaned, reassembled, and adjusted before they would run well and maintain accuracy. The two individuals who performed this work have a combined 75 years as machinist. Experience and skill turned Jet junk into jewels.
    John Taylor apparently has 22 machines in transit, but like everyone else is experiencing delays with shipments from China. He has moved to upgrade quality above that of other companies selling larger and more expensive individual units by moving his operation to the ISO 9001 certified plant.
    Dec 2007
    Quote Originally Posted by Roadster View Post
    I think that original thread was false and done by one or more of the perrennial whiners. If it were true, you would think they would be happy at the prospect of someone new taking over the company since their issue seems to be with JT himself.
    Banned
    Nov 2007
    You have to stand up to your product and cover your warranty's and JT has failed to do so. As for false posts I cant say since there are so many here I cant tell anymore.
    Jan 2008
    Quote Originally Posted by sharpshooter90 View Post
    Some guys are so blinded by frustration that they can't see a good deal coming. I'm sure that investing all his money in a car company that went bankrupt and is on the verge of being sold to the Chinese doesn't brighten his day either.
    May 2009
    Question to digital
    You had a bad casting and it was replaced with a repaired unit...not new. I spent 16 years in purchasing for equipment which included machines which cost up to several million dollars. Our contracts called for spares of specific quantities. Castings were considered no wear items so the spares were few if any. It was not uncommon for the vendor to replace cracked or defective castings with repaired units.
    The vendor, Shoptask, apparently followed accepted practice with his replacement to you. If you weren't satisfied, you had the option to return the entire machine for a refund less shipping. Did you attempt to return the machine for a refund less shipping under the terms of the warranty, which you knew in advance, or did you simply keep the machine?
    Another poster gave his machine away. Norvil. Did you attempt to return your machine to the vendor under the terms of the warranty? That was your option which you knew in advance of purchase. Did you attempt to clean and adjust the machine as is accepted practice with non ISO 9001 equipment from China in an attempt to achieve expected accuracy and performance? Do you have the technical expertise to perform such maintenance on this type of equipment to achieve such performance without damaging and diminishing the capability of the machine?
    The owner of Shoptask, to his credit, realized the quality issues with his machines and moved his operation to a ISO 9001 production facility.
    Have either one of you used the Patriot machine produced in the ISO 9001 certified facility?
    Banned
    Nov 2007
    I had a brand new machine . It was sent with a welded casting. It leaked. He sent me a casting that had been sitting around for years. It was cracked. I had to use my own money to fix the casting. I had no help from John Taylor.He did nothing for me except try to pawn off another bad casting to me for a brand new machine. You have not read the post through have you.
    May 2009
    Yes, I've read your post.
    I've read your post. Did John Talylor have any way to know that the original casting was defective prior to you receiving the machine?
    He apparently has listened to customer complaints, successfully fixed most problems, and even moved production to a factory with higher quality control standards to provide a better product.
    Apparently, you fixed the problem and your machine is fixed now. Perhaps your situation helped with his decision to move his production to an ISO 9001 certified facility. I imagine that John Taylor and owners of the new Patriot appreciate your input to Shoptask.
    I know some people's intention was to harm Shoptask and you may have done slight damage. But like any truly conerned owner, it seems the owner of Shoptask took constructive action to produce an better product. The new Patriot uses Meehanite castings which are superior to the castings in the older machine.
    Give yourself a little credit. You probably are somewhat responsible for helping create a better product.
    Feb 2009
    Quote Originally Posted by smallblock View Post
    If its Chrysler you are talking about, you're right. The Chinese are working the sidelines on this one. Fiat will get a 20% stake in Chrysler with a loan from US taxpayers. The Chinese are poised to buy up the Jeep brand from the Italians. The Jeep Cherokee has been built in China for near 20 years now and they have the experience necessary. This whole scenario has caused the book value of Jeeps to drop by 50% since 2007 and more to come. Inexperienced young buyers may buy a China Jeep or a Fiat-Chrysler, but anyone who remembers the Fiats of the 1970's will avoid them like the plague.
  • Page 1 of 3 123 LastLast
    1. selling VM1
      By john whidden in forum HURCO
      Last Post: 03-16-2012, 12:21 PM
    2. Need Help!- shoptask
      By 1bankerjd2 in forum Shopmaster/Shoptask
      Last Post: 09-20-2008, 03:44 PM
    3. Looking for Used Shoptask
      By fastlanecafe in forum Shopmaster/Shoptask
      Last Post: 02-20-2008, 08:49 AM
    4. shoptask cnc option
      By swilliams in forum Shopmaster/Shoptask
      Last Post: 05-02-2006, 09:10 AM
    5. Shoptask Or Not ????
      By 76OLDS442 in forum Shopmaster/Shoptask
      Last Post: 05-19-2005, 07:52 PM
