Results 1 to 3 of 3
Thread: jenix DRO problem
    Registered dahui's Avatar
    Dec 2005
    jenix DRO problem
    Hi all,
    So I have Jenix DRO that has worked great up until now and it seems to have lost it's mind. Every time I power it off, leave it for a while, and power it back on it seems to have "reset" itself. As in...every lamp is lit and I have to go back and reconfigure all of the settings. After this it works fine until I turn it off again.
    Is there a battery that I need to change? I couldn't find my manual anywhere.
    Feb 2009
    Our machines have the "power outage" memory, so there must be a battery inside. My manual does not say anything about how to change it. Are you using the front screen on/off button or the power on/off switch in rear? If you use the rear switch that kills all power and may lose the charge. The front screen button turns off the LED's, but leaves the board powered up. JT sent me some extra manuals because around here things disappear regularly- he could probably send you another.
    Dec 2005
    okay thanks, time to get out the screw driver.
  1. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 10:51 AM
