Results 1 to 2 of 2
Thread: How to remove the R8 arbor in the mill head??!!
    Jul 2007
    This is probably a dumb question but how on earth am i supposed to remove the drill chuck arbor that came installed in the mill head??
    I want to use an r-8 collet and I am guessing that once I remove the chuck arbor then i will be able to slide the r8 collet into the mill head.
    I looked everywhere for some sort of tool that might have come with the machine but no luck.
    Thoughts??
    Will
    Jul 2005
    It should be held in by a draw bolt that comes down from the top through the center of the spindle; there will be a hexagon head at the top above the pulley. The quill has to be all the way up to see it.
    Slacken this no more than three turns and then give it a sharp hit with a medium size hammer and the R8 taper should come loose.
  1. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills & Lathes
    Last Post: 11-18-2009, 05:48 PM
  2. Can I remove this from my mill head?
    By cnczoner in forum General Metal Working Machines
    Last Post: 08-14-2008, 05:16 PM
  3. Help - remove head on 45 Square Col Mill
    By kramerda in forum Benchtop Machines
    Last Post: 12-22-2007, 10:49 AM
  4. Need an R8 Shell Mill Arbor
    By CoolHand in forum General Metal Working Machines
    Last Post: 02-02-2004, 09:02 PM
