Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 01-05-2005, 12:23 AM
Texasj10 is on a distinguished road
Question CNC conv. info help needed
I am working on converting my shoptask eldorado bridgemill to cnc. I think that the timing pulleys I need are XL style, 21 tooth, with .375 bores to go with the steppers I purchased from Camtronics. Can anyone confirm this pulley size and type being right and can anyone provide the belt part numbers I need? Also does anyone have a source for the required pulley? My standby MSC doesn't have a .375 bore xl if that is indeed what is required.
Old 02-26-2009, 12:34 PM
jdclark is on a distinguished road
Originally Posted by Texasj10 View Post
I am working on converting my shoptask eldorado bridgemill to cnc. I think that the timing pulleys I need are XL style, 21 tooth, with .375 bores to go with the steppers . Can anyone confirm this pulley size and type being right and can anyone provide the belt part numbers I need? Also does anyone have a source for the required pulley? My standby MSC doesn't have a .375 bore xl if that is indeed what is required.
My machine came with all the pulleys as standard equipment- i think your model should have also, unless you bought it used. I think shoptask could supply the right pulleys and belts for any of the older machines.
Old 01-14-2010, 10:51 PM
Sprint 77 is on a distinguished road
I am converting my Shoptask to CNC also and I am also from Texas. I am now getting ready to fit my ballscrews into the machine and finalize my extra 5 inches of y axis travel
Old 01-15-2010, 10:35 AM
GITERDUN is on a distinguished road
One of the things I really love about my Patriot is that all of the drive pulleys and mounts are included when you buy the machine. I've done retrofits before on other machines and its always a huge pain to have to design and fabricate all that stuff.
Which model do you have? I would like to see some pictures of how you are gaining 5" extra Y travel.
Old 01-15-2010, 11:41 AM
Yes my machine came with all the CNC pulleys too. I just need to buy and grind to spec the ballscrews
Old 01-17-2010, 12:30 AM
Ballscrew and extended travel install
Well I am waiting on my "Y" axis ballscrew to get here. I got some of my parts int Solidworks.
I put the square nut in from the Data sheet that went with my ballscrew. I also got my extension parts in to check out how I am going to do the reverse direction Gear to gear drob down to make my handle work right in manual since my ballscrew unlike the left hand Nook that they sell for the shoptask is a right hand.
Anyways check it out someone was asking about my extend table travel .
Name:	extendension assembly.jpg‎
Old 01-23-2010, 11:06 AM
My Ballscrew for this "Y" axis conversion will be here Tuesday according to UPS
Old 03-12-2010, 05:36 PM
Got any pictures of the finished table extension?
CNC mini-lathe conversion help needed. minilatheman Mini Lathe 5 05-24-2005 08:47 AM
Advice needed: Buying a CNC vs retrofitting a manual jkeyser14 General Metal Working Machines 0 11-17-2004 01:03 PM
D&M Computing CNC 9 Lathe Info??? TD1932 General Metal Working Machines 1 10-11-2004 04:16 PM
what is needed to build a cnc table(plasma) Apples CNC Plasma and Waterjet Machines 13 06-28-2004 07:03 PM
