Results 1 to 3 of 3
Thread: Stainless Steel
    Feb 2009
    Stainless Steel
    Anyone familiar with stainless steel? I have some potential jobs, and would appreciate any info on types of cutting tools, coolant, feed rates etc.
    Thanks in advance
    Registered mc-motorsports's Avatar
    Feb 2007
    What grade? What ever you get, watch the temper, especially if your milling plate which is readily available 1/2 hard, not so easy to find annealed, atleast with my local suppliers.
    What process? Milling, turning?
    Coolant, if any, depends on process and tooling.
    Tooling depends on process, machine ridgidity, grade of stainless, spindle horsepower and RPM. So on and so forth.
    You should probably post as many details as possible so people can argue over the best answer.
    Feb 2009
    Stainless 47 S.F.M. for hss drills. 1" dia. feed at 0.004-0.006 per revolution. That is a very moderate speed and feed rate , one that will provide excellent tool life. Peck at 1/2 the dia. of a drill. 1' drill peck at .500 or less. Don't work harden the steel, (over heat) if that happens try carbide to get past the "CRUST" thanks for asking. Stailess has been cut since your daddy was a kid.
  1. Stainless steel
    By larry53 in forum General Metalwork Discussion
    Last Post: 04-23-2007, 12:32 AM
  2. Steel or Stainless
    By tool_man in forum Casting Metals
    Last Post: 10-29-2006, 06:46 AM
  3. Stainless Or Steel
    By 69owb in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 02:43 PM
  4. Stainless Steel ?
    By Depoman in forum General Metalwork Discussion
    Last Post: 01-12-2005, 06:40 AM
  5. Is stainless steel
    By CNCadmin in forum Hard and High Speed Machining
    Last Post: 10-17-2003, 09:19 AM
