Results 1 to 5 of 5
Thread: 1720 Table Mount
    Jul 2008
    1720 Table Mount
    I just took ownwership of an older 1720. I'm looking for suggestions on a table/bench to mount this on. It specs at 700 lbs, but I've had a hard time finding benches that specify a weight capacity. Does anyone know of a table that will hold this up. Thanks a lot
    Greg
    Jan 2008
    On my 1720, I bought a bench from Harbor Freight. It was a sheet metal style rated at about 500#, but I put in some angle iron braces to stiffen it up- Price then was about 100.00. If you have the original manual, there should be some plans in the back on how to build a bench yourself.
    Dec 2007
    Quote Originally Posted by gpcoe View Post
    Greg
    Grainger has a nice cabinet with locking front doors - part # 1W814. Two of these bolted together make a nice stand with 8 legs- should be plenty strong for your machine.
    www.grainger.com
    May 2005
    17-20 Table Mount
    I realize this thread is a few months old, but...
    I have a 1720 3-in-1, now 10 years old. I utilized the black stand that came with mine and put a 60"x30" Bally Block laminated wood benchtop bolted through the stand into the lathe casting underneath. Sandwiched between I put a big galvanized oil drip pan I got from Napa Auto Supply and I siliconed caulked it to get a fairly good leakproof integrity to it. Then I bolted 3/4" plywood sides around it and electrical conduit and plenty of places to plug electricity outlets to it. And added two drawers under it and a shelf. Works great, but a lot of work building it.
    Smithy has a bench stand I am going to use for my Sieg mill, though it is overkill for that purpose. But it would have been great for my Shoptask and it was rated half a ton capacity at the time:
    http://www.smithy.com/accessories.ph...77&code=80-045
    Sep 2006
    Wisconsin USA
    This may be a little late but for my Jet 1325 I used a medical exam table. Took the pad off and placed a heavy sold chunk of wood (old door) for a base. I put a brace from the table to the wall for added support. The exam table comes with several drawers for storage, has an outlet on it. Of course you should take off the stirrups and such. The best part was the place I got it just wanted it gone, taking up too much space. My table turned out to be a retro greenish color. I since picked up a couple more and gave one to my brother for a workbench and another sold on ebay for $200.
    1. Need Help!- Siemens 810M 1720 ORD + X error (Motion Master Router)
      By mjhjenks in forum Controller & Computer Solutions
      Last Post: 03-02-2010, 05:06 PM
    2. basic ?s on Shoptask 1720
      By laskaboots in forum General Metalwork Discussion
      Last Post: 08-11-2007, 12:49 PM
    3. 1997 Shoptask 1720 Gold
      By Rainone in forum Shopmaster/Shoptask
      Last Post: 05-09-2007, 11:49 AM
    4. Tool Mount For Jacobs Taper 3 mount
      By pzzamakr1980 in forum Tormach Personal CNC Mill
      Last Post: 03-29-2007, 03:31 PM
    5. How would you mount a servo to this Rotary Table?
      By replicapro in forum General Metal Working Machines
      Last Post: 07-05-2004, 05:37 PM
