If you are still concerned about the bed levelling issue, reach up under the bed and feel for the cross ribs. If you ever look at the bottom side of the base casting, you will find that it is about 3/4" thick and has big cross ribs about every 6" along its length. If the bench top is not level, its most likely that it will conform to the bed when you tighten the bolts rather than the other way around. The threads in the base are 10mm, the same as the bench feet, so you could use them, but then the machine would be free to slide around on the feet.
LinkBack URL
About LinkBacks
