Results 1 to 5 of 5
Thread: newbie intro and question
    Nov 2008
    Hi just wanted too say hi.Very newb too machining and cnc.
    Looks like a great site and ill probobly be reading here alot.
    Just picked up a 17-20 xmtc.Has the the DRO,Ball screws,CNC from shoptask,fastcut system.this is a 1997 model.
    And best of all believe it or not it was free.
    I have the original manuals and the machine is complete andnot used very much.
    My main question is what will i have too do too this machine too make it run on a modern software package like mach3 for example.
    Will the contol box on the machine now work with rewiring and a new computer.or will i have too get new drivers also.
    Thanks for everybodys time.Hoping too get it running and start practicing.
    been reading alot of books and internet info.Going too try some projects manually then hopfully get it running cnc.
    Dec 2007
    Wow- that sounds like a great deal- If your CNC is FLASHCUT- you may need to contact them about upgrades. Shoptask switched to MachIII based systems years ago due to the odd proprietary system offerred by Flashcut. With zero invested, you could upgrade to the quadra lift version and come up with a nice machining center for very little money. I had a quadra lift unit which made me enough money to buy a new Patriot.
    Aug 2006
    you will soon find out why the price was so cheap.
    Jul 2005
    I got a used Quadra lift from an estate- it wasn't free, but it was a good deal for the money. Shoptask uses Nook ball screws, and I did my own conversion. They come in a lot of configurations. Ground screws are way too expensive, but you can get the select fitted rolled threads pretty reasonably. Thats what I got for mine and the lash is about 0.004". You can also get the double pre-load nuts which have zero lash, but the length costs you some table travel. If you have more than 0.004", you may have the standard nuts, but they can be upgraded by switching out the balls. Be sure to check your gib adjustments and also the screw mounts to be sure any lash isn't from some loose components.
    Feb 2009
    Quote Originally Posted by rathgar View Post
    Did you ever get the CNC portion running? What do you think of the fastcut ?
    1. Newbie Intro and I hope I'm in the right sub forum
      By Gerry Sweetland in forum Benchtop Machines
      Last Post: 11-13-2008, 03:13 PM
    2. Intro and Question About a Webb Mill
      By bml6116 in forum General Metal Working Machines
      Last Post: 04-27-2008, 02:49 PM
    3. Intro and step/direction question
      By The President in forum Servo Motors and Drives
      Last Post: 03-02-2008, 09:49 PM
    4. Newbie Intro, Torchmate
      By carl coleman in forum Torchmate
      Last Post: 01-29-2007, 11:47 PM
    5. newbie question
      By leroy in forum General CAM Discussion
      Last Post: 07-03-2004, 12:15 AM
