Results 1 to 4 of 4
Thread: shoptask lathe spindle mill work
    Nov 2008
    MY shoptask came with a drawbar for the lathe spindle. I assume this bar is inteded to attach collets to the spindle for various purposes. What sort of collet fits the spindle taper and draw bar? I wonder, if an end mill and milling attachment to the table would provide a means to accomplish viration free heavy milling. My mill head does very good work, but, heavy cuts do generate a good bit of vibration.
    leeharrysouth
    Aug 2005
    The lathe spindle bore is supposed to be a Morse #4 taper. There are #4 taper collets available and that is what the draw bar is for. Sizes are somewhat limited though.
    Jul 2005
    The lathe spindle has a Morse 4 taper because it was designed to do lathe work between centers. Morse 4 collets are available, but are hard to find and usually expensive. A cheap alternative is to buy a 5C collet block set and some 5C collets. The collet block runs about 30.00 from a number of tool stores. It contains a Hex piece which you can grip in your 3 jaw chuck- just make up a drawbar and voila you can use 5C collets. The accuracy will only be as good as your lathe chuck, but for most stuff it is fine.
    Nov 2008
    collet block
    Thanks for the tip. I may give it a try.
    leeharrysouth
  1. Some Shoptask work, pictures
    By ozzie34231 in forum Shopmaster/Shoptask
    Last Post: 08-13-2009, 04:49 PM
  2. RFQ mill and lathe work
    By timmydabull in forum Employment Opportunity
    Last Post: 06-20-2008, 04:48 PM
  3. shoptask 3/1 lathe/mill assembly and mods
    By Bloy2004 in forum Shopmaster/Shoptask
    Last Post: 01-24-2008, 09:06 PM
  4. RFQ - Lathe & Mill Work - Toronto/GTA
    By ngr1 in forum Employment Opportunity
    Last Post: 07-15-2006, 11:48 PM
  5. Anyone want to do a little lathe/mill work?
    By Cold Fusion in forum Employment Opportunity
    Last Post: 07-27-2005, 02:07 PM
