Results 1 to 2 of 2
Thread: Drain Tube Problem
    Jan 2008
    Drain Tube Problem
    I am assembling a new Shopmaster Patriot. It appears there is a problem with the design of the drain tube for the coolant system. The flanged drain tube mounts above the pan. It will sit about 1/8 inch proud, and therefore not drain 1/8 inch of coolant from the pan. This will mean approximately a gallon of coolant will not drain from the pan.
    It also does not appear the pan is sloped to the drain.
    Has anyone mounted the flange below the pan, with an o-ring or rubber gasket and sealed the bolt holes?
    If not, how do you drain your coolant from the pan?
    Jan 2008
    There is a section in the manual called " preparation of your bench" it tells you to place the tube on the under side with bolts on top and use silicone to seal around it.
  1. TM-1P chips plug drain too fast
    By juxtoposed in forum Haas Mills
    Last Post: 05-06-2008, 06:52 AM
  2. Drain Pre-screen
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 03-14-2008, 12:37 AM
  3. Replies: 4
    Last Post: 03-11-2008, 02:43 PM
  4. SL-10 Coolant Drain Upgrade
    By Edster in forum Haas Lathes
    Last Post: 01-20-2008, 11:01 AM
  5. Is this a bad tube?
    By FlyGuy007 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-13-2007, 06:44 AM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
