Results 1 to 6 of 6
Thread: Shopmaster start/stop button died
    May 2006
    The start/stop buttons on my 2003 Bridgemill have both fallen apart.
    I use the lathe on a production job that requires me to use the start/stop button alot. I wore out the lathe button, switched it out with the mill button
    and have now worn it out. Wondering if anyone has "upgraded" to another type of start/stop switch?
    David.
    Dec 2007
    On the machine our unit had, we did a lot of milling, and found that the contact points on the forward side got pitted- we switched them out with the points for the reverse side which were seldom used. We used the hi-low spindle brake on the lathe, so the switch was only used a few times per day. You could always change them out for a drum type switch, but that might be costly and require some knowledge of wiring. Otherwise just buy a couple new ones from shoptask and figure to get another 5 years use.
    Banned
    Nov 2007
    Grainger sells drum switches at a good price.
    Jan 2008
    My original shoptask was equipped with rotary style switches, which began to get loose after about 6-7 years. I considered upgrading to the push buttons, but it required cutting 2 rectangular holes in the sheet metal. Eventually I found a couple of 3 pole double throw toggle switches at the surplus center for 5.00 each and they fit in the original switch holes.
    May 2006
    Thanks for the suggestions.
    David
    Registered dahui's Avatar
    Dec 2005
    i have two sets of start/stop/reverse buttons sitting around. They are about 98% new. I switched them out for allen bradleys and contactors when I did my VFD upgrade.
    I'll part with them for 15 bucks for one and 25 for two. I'll pay USPS shipping.
    Normally I would give them away but I've been hitting the credit card pretty hard lately.
    1. E-Stop Button
      By widgitmaster in forum General Electronics Discussion
      Last Post: 05-19-2008, 03:41 PM
    2. Help with e-stop button
      By Astroguy in forum Xylotex
      Last Post: 05-31-2007, 08:23 AM
    3. Where do I install an emergency stop button?
      By alexccmeister in forum Stepper Motors and Drives
      Last Post: 04-21-2007, 07:40 PM
    4. Arcade Button Emergency Stop
      By mikkojay in forum Gecko Drives
      Last Post: 06-07-2006, 01:30 AM
    5. Cycle Start button
      By kaleem1 in forum Mach Software (ArtSoft software)
      Last Post: 12-24-2005, 03:05 PM
