The older Shoptask machines required disconnecting the ball screw in order to use the power feeds, but my Patriot has manual, power and CNC drives functional at all times. I had considered going to ball screws, but the standard acme is pretty accurate at 0.0015" backlash. I would have had to use a really expensive ground ball screw to get any tighter. Keep us posted on that teflon coated gib strip idea if it reduces table friction.
LinkBack URL
About LinkBacks
