Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 04-12-2008, 01:11 PM
brucesu1 is on a distinguished road
gang tool holder
Does anyone know if a gang tool holder is available for the eldorado bridgemill when in the lathe mode. Would like to know source if any capable of holding at least eight tools.
Old 04-12-2008, 10:13 PM
mixdenny is on a distinguished road
Do you mean an indexing tailstock turret? The most tool positions that I have seen for one that fits a 3MT is 6 tools.
Dennis
Old 04-13-2008, 03:04 AM
No. On the axis normally used for cuting threads etc.
Old 04-13-2008, 10:09 AM
I think it would be so big it would be in the way on such a small lathe. A quick change tool post takes only a few seconds to swap holders and the tool height is preset, might that meet your requirements?
Dennis
Old 04-13-2008, 11:54 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
I'm guessing you'll have like 10" of travel? A purpose-built small gang lathe like an Omniturn GT-Jr has 9" of travel, so this is doable.
FWIW, here is my page where I am designing a gang slide for my small lathe:
http://www.cnccookbook.com/CCLatheCNCGangSlide.html
It's a long-term project, so don't hold your breath for updates, LOL.
You should also consider a turret. Hardinge turrets are available used from eBay at decent prices. Two threads here on the 'Zone are really worth looking at in conjunction.
First, Widgitmaster built a manual turret from one for his manual lathe:
http://www.cnczone.com/forums/showthread.php?t=33813
I'd read through that and you'll get a lot of good info.
Second, have a look at Vince's rebuild of a Hardinge CHNC lathe which is the CNC version of this turret:
http://www.cnczone.com/forums/showth...highlight=chnc
Good pix and data on how he is setting up his turret.
Whatever you decide to do, it's worth noting that the Hardinge turrets, and a lot of gang tooled lathes like the Omniturn all work with the same tooling. I plan to use those T-slot dimensions so I can take advantage of all the used tooling available on eBay.
Cheers,
BW
Old 04-13-2008, 04:25 PM
gang tool holder
The joint plan looks like it will be 2 quick change tool holders for the time being and then probably custom fabricate a gang too holder.
Old 04-13-2008, 07:12 PM
dahui's Avatar
dahui is on a distinguished road
What about a small tool post for each tool?
Old 04-14-2008, 03:09 AM
gang tool holder
That is a viable option but I may just make it on 1 block of metal.
Old 04-22-2008, 08:34 AM
I noticed a Dorian manual vertical index turret that holds 8 tools in the JTS catalog, page 500. It doesn't show up on the JTS website. The Dorian catalog doesn't have a direct url, but you can go to their catalog and select the turret section:
http://doriantool.com/
It's pretty high end, I guess, the set that fits a 12" lathe, part number S-NVIT8-50 from JTS is $2151. Here are some screen caps from the Dorian catalog. Dennis
ID:	58197   Click image for larger version
ID:	58198   Click image for larger version
Taig Mill converted to a gang tool lathe... Anokiernan Taig Mills & Lathes 5 02-16-2008 04:10 PM
Km-3P Tool holder woodr004 HURCO 1 09-17-2007 08:24 AM
Tool Shift for gang tooling elaganis Haas Mills 20 03-09-2007 03:48 PM
Setting up a gang bang drill holder joseavina76 General Metalwork Discussion 2 10-02-2006 10:28 AM
Gang tool cnc mini? Call Maker Mini Lathe 6 03-26-2006 11:38 AM
