Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 04-12-2008, 07:54 AM
bprager is on a distinguished road
Question Splash lube of spindle bearings
According to the manual, the spindle bearings are splash lubricated. As I'm about to replace the spindle bearings, I have a question. Should I pack the spindle bearing in grease if they are splash lubricated?
It would seem that you would slowly contaminate the oil with the grease in the bearings. If it is splash lubricated, my past experience with such systems is that the bearings are soaked in the same oil as the splash system, and the splash system keeps them lubed.
But if seems that Shoptask recommends greasing the bearings, and then splash lubricating them which doesn't make much sense to me as the oil won't make it thru the grease, or if it does, will wash it away.
Any advice from other owners or experts our there as to what way makes the most sense?
Old 04-12-2008, 10:21 AM
brucesu1 is on a distinguished road
I know very little about it. My understanding at this point is that the lathe bearings are splash luricated. The mill bearings are grease lubricated. My advice would be to call shopmaster on there tool free line and ask them if this is the case.
Old 04-12-2008, 11:38 AM
I've tried that. JT says he doesn't know. He says the spindle is splash lubed, but doesn't know why you then need grease.
That's why I'm posting it here. To me, bearings should either be splash oil, or grease packed lubricated. Both doesn't make sense to me but maybe I'm off base, or the splash lubrication (despite the manual) doesn't reach the spindle bearings and really only lubes and cools the transmission gears. That is the only way to me, it would make any sense.
Any comments or experiences for other owners?
Old 04-12-2008, 11:49 AM
mixdenny is on a distinguished road
I have always wondered about the splash lubricated bit myself. It doesn't seem like there is a real positive flow path for the oil. It would be neat to replace the cover plate with plastic for awhile to see how much oil actually gets up there.
Dennis
Old 04-12-2008, 12:11 PM
dahui's Avatar
dahui is on a distinguished road
Ah ha! Another good one. I know from my bearing swap that the lathe bearings were greased from the factory.
However, I'm dubious about how much splashing is going on up there. I got a hunk of lexan to use as a cover but ended up removing the tripple gear and hence the ability to splash lube...and then didn't ever put the cover back on. So, I just greased the bearings. I figure if grease works for the mill then it should work for the lathe. I can't see any major harm in having grease and splash though. Based on the ammount of grease still in the bearings it didn't look like any of it has been "washed out" by the oil.
Old 04-12-2008, 10:28 PM
*Registered*
digitalmdj is on a distinguished road
The only time that the lathe spindle bearings can possibly be splashed lubricated is when the power feed is engaged. So you better grease the bearings.
Old 04-13-2008, 03:15 AM
Seems to me that the need for the power feed on to splash lube the spindle bearings was in the manual as well.
Old 04-13-2008, 07:15 PM
dahui's Avatar
Wow you actually read the manual? Is there anything else I should know?
Old 11-08-2008, 08:24 AM
leeharrysouth is on a distinguished road
splash spindle bearing lubrication
Did anyone ever get a real awnser on this issue of grease or no grease for lathe spindle bearings. I also talked to jt some time ago and he could not seem to give me a exact awnser either. When I replaced my spindle bearings on the headstock I think I did grease them, but, as many I wander why I did grease them.
leeharrysouth
Old 11-08-2008, 09:45 AM
Splash lubrication
Yes, the manual says to keep the trans in gear at all times to lube the bearings.
The oil would have a real hard time getting into the bearings considering that its only the gears that sling, not a sling ring which is used in most splash systems. (At least the ones I have seen.). There really isn't a lot of gear in the oil and its at the very bottom. How it can splash much up and sideways was always a mystery.
I lubed mine, but always wondered how much oil really got to the bearings rather than to the main drive gear. Will probably remain a shoptask design mystery<g>!
  #11   Ban this user!
Old 11-08-2008, 01:43 PM
fastlanecafe is on a distinguished road
After I did the headstock alignment I ran the lathe with the mill head removed, and the oil definitely will splash out the hole in the top of the casting. JT warned me not to overfill the gearbox or it would leak out around the handles, so I think the answer is yes the oil will splash lube the bearings.
  #12   Ban this user!
Old 11-09-2008, 09:08 AM
crsatter is on a distinguished road
leeharrysouth
I have been a mechanic for 42 years. Anytime I take something apart that has any kind of bearing I always put on some grease when I reassembly. When the machine initially starts everything is lubricated untill the lube system takes over. It has always worked well for me.
Spindle lube QSIMDO Industrial Hobbies (Support forum) 2 10-08-2007 05:23 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
what kind of lube for linear bearings? Harold Edwards Linear and Rotary Motion 2 05-20-2006 10:32 AM
Spindle lube on 4020 Fudd Fadal 4 01-22-2006 11:31 AM
