Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 08-15-2004, 02:47 PM
atemylunch is on a distinguished road
Question?
I have an old 97 model shoptask. W/Flashcut CNC option.
I have since gone to bigger and better tools.
I still wanted to put it to use.
So, I was thinking of using it as a digitiser.
Take the Flashcut drive and connect it to DeskCNC's controller board(w/touch probe).
For improved accuracy, I would replace the existing screws with preloaded acme screws.
What do you guys think?
Old 09-04-2004, 08:53 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Hi atemylunch,
sorry for the delay in commenting.
I've used my shoptask for digitizing using Mach2 digitizer feature, so I would say to "go for it". If it doesn't work out, you will have learned something anyway.
Old 09-11-2004, 09:38 PM
Bloy,
How well did the ST work out as a digitizing platform?
Old 10-05-2004, 01:15 AM
Bloy2004's Avatar
Fumbling Machinist
wow! I missed this one...
I actually used the jpg import feature and turned a photo(after making a grayscale copy) into a relief carving similar to a coin surface. The toolpath in Mach2 showed a real nice depiction but I stopped short of milling/routing it out so as to setup a vacumm system to collect the sawdust. That's still pending as I have since switched to getting coolant up and running. But that is on hold as I am doing other activities that keep me just spraying the cutting with canned coolant. will get to it as winter sets in.
I guess I'm saving the digitization feature for a router I'm collecting parts for as that will be mainly for wood. 'am ready to start the frame soon.
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 01:51 AM
Question about power supplies dowling177 General Electronics Discussion 1 01-28-2005 08:01 AM
Hobbycnc controler question chas Hobbycnc (Products) 3 09-09-2004 06:00 PM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 09:36 PM
HF lathe question rs1300 General Metal Working Machines 0 01-19-2004 12:22 PM
