Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 03-31-2008, 09:42 AM
sharpshooter90 is on a distinguished road
Auto Stop Upgrade for older machines
On my Shoptask I had bent my auto stop arm when I engaged the drive beyond the detent position. If you do this it puts the arm at a near horizontal position and can cause it to bind up and bend the arm or break the rod-end connector. JT send me replacement parts for free along with a swivel connection modification. Here are some photos of a modification made by another customer. This is a piece of tubing bored to fit around the original mount and held in place by some screws. It has a relief milled into it and a roll pin which prevents the shifter from being engaged beyond the detents. It looks like an easy thing to build and a better idea than the swivel connection. It would fit models from 1997 up to 2005. I'm not sure if it would fit on the Tri-Power or Patriot machines
Name:	AUTOSTOP UPGRADE 1.jpg‎
ID:	56680   Click image for larger version
Name:	AUTOSTOP UPGRADE 2.jpg‎
ID:	56681   Click image for larger version
Name:	AUTOSTOP UPGRADE 4.jpg‎
Old 04-01-2008, 02:37 PM
mixdenny is on a distinguished road
I like it. Now to find some 2 1/2" stock! And a rotary table, although I guess I can come up with the milled-away sector some other way. I could use bolted on stops instead of the recess, but that sure looks professional.
Dennis
Retrofitting an Older Light Machines CNC Lathe brainstatic General Metal Working Machines 4 02-01-2009 07:35 PM
Tool Change - Can I set it to auto stop? inthezone Fanuc 16 01-22-2008 05:56 PM
Keep It Or Upgrade?...Older Sherline CNC Lathes Too_Many_Tools Mini Lathe 6 05-27-2006 07:27 PM
Keep It Or Upgrade?...Older Sherline CNC Mills Too_Many_Tools Benchtop Machines 5 05-23-2006 06:46 PM
TC,1 On newer controls what about the older machines.. chipsahoy Fadal 2 04-07-2006 06:59 AM
