Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 03-13-2008, 05:57 PM
smallblock is on a distinguished road
CHEAPY TOOLPOST GRINDER
Here is a picture of a little toolpost grinder I made for my old shoptask. Its just a Harbor freight air grinder that I zip tied the throttle open and used a paint gun regulator to adjust the speed. It has a 1/4 collet, so it holds a whole variety of little stones and burrs. When my chuck jaws started getting worn I was looking for a way to clean them up and the grinder idea came to me. I found a drill holder at Lowes that was used to clamp a drill motor and make a low budget bench grinder. The diameter was almost exactly the same as the HF air grinder and it had a swivel as well. I just made a plate for a couple of T nuts and mounted it to my table. To true up the jaws, I used a bearing race on the outside of the jaws, figuring that opening against this round part would set the inner jaws at center. I then turned the chuck slowly and ground the jaws with my HF special- came out nice. I have used it on some other shafts, and with a little WD 40 while grinding you can get a real nice finish. On my patriot machine it is a bit above center due to the thicker table on the new machine, so I will have to mill down the plate a bit.
Name:	PAT AIR TOOLPOST GRINDER.jpg‎
Rear toolpost operations? zephyr9900 Mach Lathe 4 10-12-2007 04:00 PM
QC toolpost problems daedalus Mini Lathe 4 09-23-2006 04:43 PM
QC toolpost Cocotmm Mini Lathe 0 02-07-2006 10:07 PM
Quick change toolpost Klox General Metalwork Discussion 3 01-10-2005 12:38 PM
toolpost height issue devinchi Shopmaster/Shoptask 4 01-08-2004 03:13 PM
