Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 03-02-2008, 09:35 AM
smallblock is on a distinguished road
DEGREEING A BALANCER ON THE PATRIOT
After verifying the accuracy of the spindle indexer on my crank, I decided to try a degreeing project. I found an old balancer that had split out on the keyway. Chucked it up and turned the OD to remove the original balance marks. Spray painted it flat black so my marks would show. I set up a carbide tool in the toolpost to draw it across the balancer for the degree marks and set my DRO to zero. Using the index pins, I first marked each 90 degree spot with a long line. Then every 10 degrees with the detent I marked a shorter line. The spindle indexer on the Patriot is marked in 360 degree increments, but only has detents each 10 degrees, so for the 1 degree marks I tightened up the spindle brake to hold the position and marked each one with a third shorter line. The spindle brake works in the neutral position, so just by shifting the spindle into hi or low, the brake releases and you can move the spindle. Once I got all the marks scribed, I sprayed the OD with flat black again and then spun the balancer and sanded it with emery paper, leaving the paint in the scribed lines. It came out nice, and I now know I can do balancers or even make custom dials if I need to.
Old 03-03-2008, 08:31 AM
sharpshooter90 is on a distinguished road
Here is another project from the Shopmaster- its a rifle stand used to adjust the sights on target rifles.
How does the degree wheel attach to the Patriot? Do you think the assembly would retrofit to a Quadra lift machine?
New Machine Build- GOT MY NEW SHOPMASTER PATRIOT smallblock Shopmaster/Shoptask 22 02-24-2009 05:23 AM
Bench shelves on Patriot smallblock Shopmaster/Shoptask 3 03-02-2008 10:12 AM
383 stroker crank on my Patriot smallblock Shopmaster/Shoptask 3 02-24-2008 07:58 AM
New Patriot Machine out gofastscottb Shopmaster/Shoptask 11 01-28-2008 07:36 AM
VFD = Balancer????? Helix60 Phase Converters and VFD 0 02-20-2007 11:22 PM
